95 chevy not downshifting - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 5th, 2013, 10:54 PM   #1
skruba
Default 95 chevy not downshifting
Have a little problem with my 95 chevy TBI with a 4l60e Trans. Just threw in a 350 crate motor truck has 38s when im out on the trails when i get into the throttle its like a dogg. But if i start off in 1st gear its all there. For some reason it doesnt want to down shift on its own. Any ideas? Maybe it needs a shift kit or is something wrong? i did not hook up the o2s when i put the new motor in because i ran new exhaust. I also installed a new fuel system new pump lines fuel filter and fuel regulator rebuild kit. because the pump took a shit.....
skruba is offline   Reply With Quote
Old August 6th, 2013, 09:48 PM   #2
skruba
any ideas?
Old August 6th, 2013, 10:20 PM   #3
Toyfish
Toyfish's Avatar
Sounds like the kickdown cable is out of adjustment
Sent from my DROID X2 using Tapatalk 2
Old August 6th, 2013, 10:43 PM   #4
TanTahoe
TanTahoe's Avatar
These don't have kick down cables.
I would look at all the plugs and wire on the trans and tcase. Make sure you didn't cut one or get mud or dirt in a plug.
TanTahoe is offline   Reply With Quote
Old August 11th, 2013, 06:56 PM   #5
skruba
well it shifts fine just the power band seems gone ? gears wouldnt cause that would it ? or not having any o2?
Page generated in 0.27167 seconds with 38 queries
