92 Jeep Comanche 5 Speed 4x4 $2900. nice 315s. 4.10 axles - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 5th, 2013, 12:51 PM   #1
coolgareray
NMU Trailcat Alumni
coolgareray's Avatar
Default 92 Jeep Comanche 5 Speed 4x4 $2900. nice 315s. 4.10 axles
92 Jeep Comanche 4.0L 4x4 5 Speed
4/23/15 Pics are a bit old. So is post. MJ now has very nice 315/75?/16 load range D hancook ATMs. 85-90% tread. Unibody in box area needs plating or make it a Cherokee parts rig. There's about $1k in tires and wheels on it now. Best offer. The external slave getup isn't a common or cheap either. Never came In a Comanche btw. This is a one off truck with a lot of money in goodies bolted to a running driving fixable or part able unit. I was DDing this until I seen the rear spring hangers yesterday.
Patch Panels
I don't need to sell this and it's my pride and joy and a rare find to find an HO comanche that I made into a more rare 5 speed 4x4 with external slave. I'd rather sell my Cherokee but I'd like to get rid of a vehicle or 2 in general.
I converted this to a 4wd from a 2wd. This was my DD the last 2+ years until 3 weeks ago when I got a new truck
-Had 165-168kk when I swapped clusters from a dummy gauge cluster to a full gauge cluster. New cluster had 200,000 even (weird but it did) now has 212k ish but has had 35 inch tires since.
-6.5 inch RC coils in the front. Rear is Sprung over Axle with 2 leafs added.
-Could use an adjustable track bar as I sleeved the stock one.
-I'd also reccemmond some shorter front brake hoses. Dodge ram ones are a bit long.
-Flo pro muffler, Could use a louder one, sounds good but i bought the wrong model, unless you're lame and like quiet.
-Underside was completely ziebart undercoated by someone but needs a patch in the driver and passenger floor.
-Rockers are gone
-Comes with sides of a 2 door cherokee to patch the bed, bed is very solide inside, just skins are rusty
-Hitch rusted off unibody and only bolted to bumper
Currently 30 front and 8 1/4 rear I swapped in. (3.55s)
-Trans and t case are from a 93 cherokee but I used a newer bell and input bearing retainer so it's external slave.
-Has a YJ shifter (taller than a cherokee shifter) I like it, but I can swap you a XJ shifter if preferred.
-Very new ball joints
-Newer axleshaft u-joints
-Trans, t case and diff fluid are newer
-All new driveshaft u-joints Front and rear and CV ball in front shaft
-Rear diff and t case seep leak.
-Newer front axle seals, think I did rears swapping the rear axle in too.
-Stops excellent, front brakes are very fresh and rears are recent and adjusted up
-Fresh engine oil
-Fresh valve cover gasket and painted valve cover
-Doors are rusty but have good shape red ones that come with
-Also comes with a set of vent windows
-Sunroof needs to be shimmed, leaks a little so headliner needs to be redone, easy to do these. I've done 3, 2 in black. 2 tone is sweet.
- I shortened the rear driveshaft myself. Has been like that for years. rides great but a professional shaft is suggested.
- Comes with the (4) 35 inch BFG all Terrains on it plus a spare but they do have cracking in the tread. The spare and RR are tubed. New tires are suggested.
-I also bent the rear rim lip once and had to hammer it back but it still balances. Suggest a new rim
-1 wheel bearing has a hair of play in it.
-Runs excellent
-New fuel filter
-New valve cover breathers
-New air filter
-Cracked exhaust manifold
-Could use plug wires, was waiting til I got the valve cover gasket done, which I did. Comes with new plugs in box.
-Newer Napa Alternator w/ lifetime warranty but needs to be warrantied, has worked fine but made a bearing noise since almost new
-Think it could use a thermostat, have one. Current is like 2 years old but seems to be running a bit cold on the gauge like it's sticking open, maybe it's the gauge. Might change this soon.
$3000 for my pride and joy. Possible trade/ partial trade. Interested in cars/ trucks I could sell, dana 60s or car/truck trailer
Gary 248 722 6314
call/text for more pics but reccemond coming to see in person.
I'm trying to be straight forward about this vehicle. Feel free to call me if you buy it if you ever have any question. Also I get dibs if you ever want to sell it
I might detail it soon and it will shine incredibly even for a rusty 92 so jump before someone else does.
coolgareray is offline   Reply With Quote
Old August 6th, 2013, 08:51 AM   #2
coolgareray
NMU Trailcat Alumni
Bump
Willing to cut a package deal if you buy my Cherokee too
99 Cherokee 5 Speed - Lifted $3200 (pics in post) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 7th, 2013, 01:31 PM   #3
coolgareray
NMU Trailcat Alumni
Bump
Filled up with a full $65 tank of premium yesterday
Old August 8th, 2013, 12:56 PM   #4
coolgareray
NMU Trailcat Alumni
Bump
might have it out at the dream cruise
Old August 11th, 2013, 05:09 PM   #5
coolgareray
NMU Trailcat Alumni
Bump I do have a Dana 30 and 35 with 4.11s or 9 inch and weld on wedge 44 I may be willing to work into the deal
Old August 12th, 2013, 09:07 AM   #6
BeardedXJ
Would you trade for a stock Cherokee?
BeardedXJ is offline   Reply With Quote
Old August 13th, 2013, 10:02 AM   #7
coolgareray
NMU Trailcat Alumni
Pm inbound
Old August 16th, 2013, 04:57 AM   #8
coolgareray
NMU Trailcat Alumni
Bump for the die hard early morning web wheelers
Old August 16th, 2013, 10:36 AM   #9
supersamikc
Yooper
supersamikc's Avatar
Send a message via AIM to supersamikc
Hahaha I heard A and L is at a decent price right now.
supersamikc is offline   Reply With Quote
Old August 17th, 2013, 07:17 AM   #10
coolgareray
NMU Trailcat Alumni
You taking in the unfinished B2? I drove these fu*kers 420 miles home. That's reliability.
Will be at Woodward today burning up the premium.
Old August 18th, 2013, 11:33 AM   #11
coolgareray
NMU Trailcat Alumni
Was 4 low creepy crawlin at wooward. People were loving the Comanche. Accepting offers. Can sweeten deal. Have new in box 8 k winch and 4.10 axles.
Old August 18th, 2013, 07:31 PM   #12
JeepManHuff
Muddin is Livin
JeepManHuff's Avatar
What's your rock bottom price on that? Definitely interested
JeepManHuff is offline   Reply With Quote
Old August 19th, 2013, 05:28 AM   #13
coolgareray
NMU Trailcat Alumni
Pm inbound
Old August 21st, 2013, 08:34 AM   #14
coolgareray
NMU Trailcat Alumni
Bump.
I forgot to mention the truck comes with this red Toyota topper. It's a hair short in the front and around an inch too long in the rear (because the front is slanted) but the width is good and it keeps the snow out of the bed nicely during the winter. Topper is structurally very sound. I had it on last in May.
For the Bark River off road races I actually threw a futon mattress in the bed and slep in there. The front side windows slide open and are screened and there's a slider window in the front.
Old August 26th, 2013, 09:33 PM   #15
mantooth
Ill give you two packs of smokes and a 30 of old style
mantooth is offline   Reply With Quote
Old August 28th, 2013, 09:08 PM   #16
TheDude
TheDude's Avatar
I really wish you were closer, this is exactly what I've been looking for..
TheDude is offline   Reply With Quote
Old November 13th, 2013, 12:49 PM   #17
coolgareray
NMU Trailcat Alumni
bump kinda fell off selling these. Willing to hear reasonable offers. Fired both jeeps up the other day. Have some other parts to negotiate with until one of the jeeps sells possibly with some of those parts but not willing to sell parts separate
-4.10 dana 30/35
-8k winch new in box
-Q78 swampers
-44/9 inch
Call text for pics
Gary 248 722 6314
Old November 16th, 2013, 10:50 AM   #18
coolgareray
NMU Trailcat Alumni
Bump
Old November 17th, 2013, 04:04 PM   #19
coolgareray
NMU Trailcat Alumni
Bump
Old November 18th, 2013, 09:07 AM   #20
coolgareray
NMU Trailcat Alumni
Bump
Page generated in 0.60502 seconds with 85 queries
