*SOLD* 99 Cherokee 5 Speed - Lifted $3200 *SOLD* - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 5th, 2013, 11:04 AM   #1
coolgareray
NMU Trailcat Alumni
coolgareray's Avatar
Default *SOLD* 99 Cherokee 5 Speed - Lifted $3200 *SOLD*
99 Jeep Cherokee 5 speed
I've owned this Jeep since 2008. It wasn't the easiest to find a new style 5 speed. I'm the 3rd owner, 1st was a lawyer I was told. I was given a ton of reciepts with the vehicle. I'm considering selling it if I can get the right price. I bought it stock (Have pics) and lifted it.
*There isn't a straight panel on this Jeep and it has some rust here and there. It was wheeled hard and wheeled too many times to count but has did awesome, and I always took care of it. Oil pressure is still excellent. With some nasty gears, possibly beefier axles it would be an even better ass kicker. Currently runs and drives, stalls occassionally but will fire up with ether, I'm pretty sure it needs an injector, I bought o-rings just haven't had a chance to look at it. I will if I get around to it. It's simple to figure out.
-14X,XXX mile Inline 6 and AX 15. was originally my DD, I got it with 108k and lifted it within 2 weeks back in 2008
-Newer Clayton 7 inch coils in the front.
-Rough Country upper and lower adjustable control arms welded solid. bushings not joint style.
-Rough Country Upper and Lower Control arm drop brackets
-Rusty's bushing to bushing track bar, bracket and frame brace.
-Rear is Rough Country 4.5 inch packs minus 2 leafs with 3 S10 ZR2 leafs and overload added and RC 2 inch Shackle. Front and rear, flexs nice. (Have pics)
-Automatic XJ axles with ZJ rear disc brakes and 3.55 gears
-220 Mig Welded (by Me) 8 1/4 Rear. Full spool weld job, spiders to each other and spiders to carrier. Has held for a few years on 35 1/2 x 10.50 swampers with a lead foot, No cracks whenever I changed the fluid and I never broke a rear shaft.
-Big joint front dana 30 shafts w/ spicer joints, could use a new joint or 2. They were a bit tight
-Could also use a slip yoke eliminator. Not a bad job to do, they run $200 for an AA but there's also a badass super shorty now available
-Currently has about 1/4 tread and slightly better dry rotted (cracking in tread)35 inch BFG Mud Terrains on brush painted hammered black steel rims. Very recently balanced.
-New fuel pump, sending unit and strainer
-Tie rod ends, Ball joints and wheel bearings have some play.
-High mounted rear shocks
-Flo Pro exhaust. Needs a patch in the tailpipe, still sounds excellent, way better than any flowmaster but a bit raspy at idle from the hole.
-Diffs, trans, tcase fluids are recent and engine oil has maybe 175 miles on it.
-Needs an oil pressure sending unit, works spuratically, I might change it soon though.
-Header panel is barely on, could use a new one, they're very cheap on ebay
-K&N in box air filter
-Recent valve cover gasket
-Recent Tune up
-Has the 99 new style intake manifold. This Jeep seems much faster than my Comanche
-Rockers need to be replaced as they are non existant. Good time to boat side.
-Newer Napa alternator
-Newer Radiator
-Needs drivers window switch
-Needs a multifunction Switch
-Air bags and clock spring are removed, needed them for another vehicle, has dummy bags in it so you don't have to stare at holes.
Inside is dirty at the moment but I'm excellent at detailing (brother is a professional detailer) and if I end up doing it I bet someone will buy it despite the body. Seriously.
I'm trying to be straight forward with you about this vehicle. If you buy it and ever have a question feel free to contact me. I also get dibs on buy back if you ever decide to sell it I just have too many vehicles at the moment and need to part with one. Also posting my beloved Comanche for sale.
Call or text for more pics. If i don't answer, I work so I'll get back with you as soon as I can, but you would be best off checking this out in person.
Price is $3200. Like I said, I had a hard time finding a new style XJ 5 speed when I got this. Possibly willing to trade/ partial trade for vehicles I could sell, Camaros or mustangs, dana 60's, car/ truck hauler trailer, straight up or you add cash. Cash or fast car preferred.
Gary 248 722 6314
coolgareray is offline
Old August 6th, 2013, 08:50 AM   #2
coolgareray
NMU Trailcat Alumni
Bump
Willing to cut a package deal if you buy my Comanche too
92 Jeep Comanche 5 Speed 4x4 $3000 (lots of pics in post) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 7th, 2013, 01:28 PM   #3
coolgareray
NMU Trailcat Alumni
Bump
has about a half tank of premium in it
Old August 8th, 2013, 12:57 PM   #4
coolgareray
NMU Trailcat Alumni
Bump
Buy it before the dream cruise and squak some tires with the Lincoln lock
Old August 11th, 2013, 05:05 PM   #5
coolgareray
NMU Trailcat Alumni
Bump I do have a Dana 30 and 35 with 4.11s or 9 inch and weld on wedge 44 I may be willing to work into the deal
Old August 13th, 2013, 10:24 AM   #6
coolgareray
NMU Trailcat Alumni
Bump
Dream Cruise is Saturday!
Old August 16th, 2013, 04:56 AM   #7
coolgareray
NMU Trailcat Alumni
Bump for the die hard early morning web wheelers
Old August 17th, 2013, 07:13 AM   #8
coolgareray
NMU Trailcat Alumni
Have an XRC 8k winch new in the box to negotiate with if you interested in the jeep
Old August 18th, 2013, 11:28 AM   #9
coolgareray
NMU Trailcat Alumni
Now accepting offers. Will detail before you come visit. You will be astounded at how clean I can make a truck shine, inside and out. Must see.
Old August 19th, 2013, 07:46 AM   #10
coolgareray
NMU Trailcat Alumni
Found injectors for $25 from rock auto. Might look into the situation this week. Like I said though, Jeep runs and drives just dies occasionally when hot but fires back up with starting fluid and can keep running with light throttle
Old November 13th, 2013, 12:50 PM   #11
coolgareray
NMU Trailcat Alumni
bump kinda fell off selling these. Willing to hear reasonable offers. Fired both jeeps up the other day. Have some other parts to negotiate with until one of the jeeps sells possibly with some of those parts but not willing to sell parts separate
-4.10 dana 30/35
-8k winch new in box
-Q78 swampers
-44/9in
Call text for pics
Gary 248 722 6314
Old November 16th, 2013, 10:50 AM   #12
coolgareray
NMU Trailcat Alumni
Bump
Old November 17th, 2013, 09:51 AM   #13
RockyMTN05
Cadillac pimpin
RockyMTN05's Avatar
Send a message via AIM to RockyMTN05
Bump for you..
Just out of curiosity, what does the first owner being a lawyer have to do with anything?
RockyMTN05 is offline
Old November 17th, 2013, 10:20 AM   #14
cwise737
cwise737's Avatar
Have a 2000 5 speed Lincoln ls if you are interested
cwise737 is offline
Old November 17th, 2013, 03:59 PM   #15
coolgareray
NMU Trailcat Alumni
Pics and details?
Old November 17th, 2013, 04:25 PM   #16
cwise737
cwise737's Avatar
160,000 miles v6 5 speed only 2331 of the manuals ever made. I love the car to death but just starting to look for a winter jeep while my yj is being built
ID:	112258   Click image for larger version
cwise737 is offline
Old November 18th, 2013, 09:07 AM   #17
coolgareray
NMU Trailcat Alumni
Texted you
Old November 19th, 2013, 02:08 PM   #18
coolgareray
NMU Trailcat Alumni
Bump for a good ride. Willing to hear reasonable cash trades or Chevy truck offers
Old November 20th, 2013, 12:14 PM   #19
coolgareray
NMU Trailcat Alumni
bump. Injectors are $35-$40. Might pull the rail soon.
Old November 21st, 2013, 10:48 AM   #20
coolgareray
NMU Trailcat Alumni
Pulled the rail today. Injectors were dirty at the rail end. Reinstalling. Might trade the xj. If I don't, buy it needing injectors running for cheaper or I'm fixing it within ten days (shipping time if I order them in 2)
Page generated in 0.33133 seconds with 85 queries
