Cj7 $1,700 ***SOLD*** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 5th, 2013, 08:51 AM   #1
charlie
Swamp Stomper
charlie's Avatar
Default Cj7 $1,700 ***SOLD***
[IMG]
1979 CJ7,
86,000 miles.
I would drive this Jeep anywhere, and I have, I've driven it to Silver Lake several times, to Grayling, West Branch, and up to Bad Axe a bunch of times, the previous owner drove it from Rhode Island to deliver it to me in Michigan, it's very dependable and very capable, it drives great on the road and wheels even better.
The drive line is pretty much stock, but it has power lock diff lockers in the stock axles, I believe it has one piece shafts in the rear, 3 speed manual trans, 5 - 35" MTR's in great shape, urethane motor and trans mounts, steering box brace, new clutch, york compressor and a two gallon tank under the hood. The stock roll bar now has a rear section and windshield bars, newer Bestop soft top in excellent condition, Cobra 40 channel CB, the seats are in good shape, I did the Blazer blower motor upgrade a long time ago so the heat is great, did the HEI ignition upgrade too, it has Warn rock sliders and a Warn front bumper, a custom 2"x4" rear bumper with tire carrier (needs to be repaired) D ring mounts front & rear, the rear Warn bumper in the pics has been replaced.
The body is not great, it's solid enough, just not pretty up close, the floors and body mounts are good, it's begging for a set of tube fenders cuz the stock ones are rusty.
Now the bad news, the passenger side front rear spring hanger has pushed up through the frame, the typical spot where these CJ frames rust, and the rear frame rails could use some attention too, I don't have the time or the tools to do the frame work and that is honestly the only reason I am considering selling it, fix the frame, and you've got a solid, reliable, and capable Jeep.
258 cid Engine pretty much stock, other than a GM HEI distributor
York OBA system
T-150 3 speed trans
Dana 20 T-Case
Front Dana 30 with power lock locker
Rear AMC 20 with power lock locker and one piece shafts???
4" Skyjacker springs
35" x 12.50" x 15" MTR's on American Racing aluminum wheels
Polyurethane bushings everywhere
$1,700.00
charlie is offline
Old August 5th, 2013, 09:02 AM   #2
dmcjeep
dmcjeep's Avatar
6 cyl or v-8?
dmcjeep is offline
Old August 5th, 2013, 07:43 PM   #3
charlie
Swamp Stomper
charlie's Avatar
6, it's got the original 258 in it.
charlie is offline
Old August 6th, 2013, 05:08 PM   #4
charlie
Swamp Stomper
charlie's Avatar
Bump
charlie is offline
Old August 6th, 2013, 09:13 PM   #5
jeepinjz
jeepinjz's Avatar
So other then the frame is is this a driver
jeepinjz is offline
Old August 6th, 2013, 11:52 PM   #6
charlie
Swamp Stomper
charlie's Avatar
Absolutely, i would drive it anywhere......seriously.
charlie is offline
Old August 6th, 2013, 11:54 PM   #7
charlie
Swamp Stomper
charlie's Avatar
York OBA system
T-150 3 speed trans
Dana 20 T-Case
Rear AMC 20 with power lock locker and one piece shafts ???
charlie is offline
Old August 7th, 2013, 01:29 AM   #8
Disl475
Send a message via Skype™ to Disl475
I would seriously buy it but coming up with $300 extra dollars to blow seems impossible FML right
Disl475 is offline
Old August 7th, 2013, 08:19 AM   #9
swampjeep
Swamp Stomper
swampjeep's Avatar
Hey Charlie, do you know what gears are in the axles?
swampjeep is offline
Old August 7th, 2013, 09:39 AM   #10
charlie
Swamp Stomper
charlie's Avatar
I'm not positive anymore John, I'm pretty sure it's 3.54, I wrote it down years ago so I would remember but.........I don't remember where I put my notes.
charlie is offline
Old August 7th, 2013, 09:44 AM   #11
Disl475
Do you have any pictures of what it currently looks like and of the affected areas I the frame?
Disl475 is offline
Old August 7th, 2013, 11:03 AM   #12
charlie
Swamp Stomper
charlie's Avatar
Passenger side, forward rear spring hanger.
Right rear section.
Left rear section.
The rear frame rails are solid on top, outside, and bottom, the last 12"-18" of the inside needs to be plated.
charlie is offline
Old August 7th, 2013, 11:35 AM   #13
charlie
Swamp Stomper
charlie's Avatar
The Jeep looks pretty much the same as the pictures up top, I pulled the bumpers off of my Rubicon to put on the CJ a few days ago, so that's not done yet, the ones that are going on the CJ are damn near as nice as the Warns, they're 2"X4" 3/16" steel, and angle cut on the bottom, but there's "W" on em.
They look like this.....hell, this might even be them.
charlie is offline
Old August 7th, 2013, 12:25 PM   #14
Disl475
It's a nice looking jeep from the first pics but man at the price to just chase that frame rust just isn't logical that frame needs replaced it will just keep creeping until there is nothing left.
Disl475 is offline
Old August 7th, 2013, 12:55 PM   #15
charlie
Swamp Stomper
charlie's Avatar
The pics make it look a lot worse than it actually is, the frame is rock solid from that point forward, the rear sections just need to be plated on the inside, and there's plenty of good material to weld in a frame repair section where the hanger is, this is a common problem on older CJ's, someone could buy all the pre made repair sections from autorust.com for $375 and weld them in, or fab the plates and do the same for next to nothing, that, and a little POR 15 and it's good to go.
charlie is offline
Old August 7th, 2013, 01:01 PM   #16
Wramblerguy
Wramblerguy's Avatar
Right rear section.
Left rear section.
That's scary
I agree its a nice looking jeep but I wouldn't drive that down the street
3rd generation jeeper
Wramblerguy is offline
Old August 7th, 2013, 01:06 PM   #17
Wramblerguy
Default Cj7
Double post
Old August 7th, 2013, 01:20 PM   #18
charlie
Swamp Stomper
charlie's Avatar
Obviously it's not drivable, it's only been moved in and out of the garage for about a year and a half now.
From my first post....."fix the frame, and you've got a solid, reliable, and capable Jeep"
charlie is offline
Old August 7th, 2013, 01:40 PM   #19
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
FYI, for those who don't know, Power lock diffs are not "lockers" they are limited slips.
BigBlockBlazer is offline
Old August 7th, 2013, 01:47 PM   #20
Disl475
Don't get me wrong I wasn't knocking the jeep at all sure wasn't my intention.
Disl475 is offline
Page generated in 0.51988 seconds with 83 queries
