My Early Bronco build - Page 7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 13th, 2014, 09:59 PM   #121
motox168
Bare Bones Offroad
motox168's Avatar
Loving the direction of thos build. Looks good Adam
motox168 is offline   Reply With Quote
Old February 13th, 2014, 10:01 PM   #122
Wramblerguy
Wramblerguy's Avatar
Right
It just seems like a lot of work for slight gain
More specifically in the front
How wide are you going and what are you doing for bolt pattern?
3rd generation jeeper
Old February 14th, 2014, 04:49 AM   #123
frdboy
frdboy's Avatar
Front will be EB width, keeping the 5x5.5 pattern.
I would have had to buy axles/gears/locker/discs for the rear either way so really other than removing and installing perches....not much more work.
Old February 14th, 2014, 05:01 AM   #124
jhnyquest
goof ball
jhnyquest's Avatar
Old February 14th, 2014, 06:42 AM   #125
Nice Adam!
Old February 14th, 2014, 06:51 AM   #126
Having run both an 8.8 and 9" in stock form, in the same type rig and same tire size/power. I never broke the 8.8, but I broke the 9".
Old February 14th, 2014, 07:33 AM   #127
Wramblerguy
That won't be too bad then
I agree the rear isn't a big deal
And since you are going eb width in the front it makes it cheaper
It will be definitely be unique and I like unique
This things gonna be sweet
Old February 14th, 2014, 10:33 AM   #128
firehawk
Live Action!
firehawk's Avatar
Depending on how you plan to mount your seats you might want to cut the drivers floor out and lower it like the passenger side.
It depends on the height of your roll cage but I would like a few more inches of clearance above my head in mine.
I built my cage so a top could be used and the seats are mounted to the cage.
I can post pics if you want.
Old February 14th, 2014, 11:03 AM   #129
frdboy
frdboy's Avatar
I have looked at your build many times Very nice btw!
I am gonna try and get the seats lower, the my cage was also built to fit under a stock hard top so room is at a premium.
Old February 14th, 2014, 02:44 PM   #130
firehawk
Live Action!
firehawk's Avatar
I bought a hard top last summer and it does not fit. It almost fits but I need to trim the inside support a little at the b-pillar. I wish I had a hard top at the time to make sure it fit, oh well just a little trim needed.
Look forward to see your progress.
Old March 1st, 2014, 09:57 PM   #131
frdboy
frdboy's Avatar
Decided to pull the bars out above the driver and passenger heads.....just didn't like them being so close.....JQ had concerns about about having them there but I was hoping to make them work. Added some grab handles and shot it with some primer for now.
Gonna pull the tub and media blast it before any more body work is done....just about ready to come off. Gonna build some bracing to keep it from moving around before we pull it.
Old March 3rd, 2014, 08:59 AM   #132
Can you kick them up and over like I did mine? They aren't above my head at all or I would have hit them multiple times
Old March 3rd, 2014, 10:04 AM   #133
Woodyjiw
FUCK CANCER!!!
Woodyjiw's Avatar
Looking great Adam!!
Woodyjiw is offline   Reply With Quote
Old March 3rd, 2014, 01:51 PM   #134
frdboy
frdboy's Avatar
Yeah......I hit my head a few times in the Mustang getting in and out.....really would not want to find out how it feels with some force
Old March 3rd, 2014, 01:52 PM   #135
frdboy
frdboy's Avatar
Thanks!
Really can't wait to start putting stuff together instead of tearing apart...
Old March 8th, 2014, 05:59 PM   #136
frdboy
frdboy's Avatar
Got the body braced up and off the frame, Thanks Tonka Toy for coming and helping out
Old March 8th, 2014, 06:00 PM   #137
So how does everything look?
Old March 8th, 2014, 06:35 PM   #138
frdboy
frdboy's Avatar
Frame is solid, body needs some floor work but other than that seems to be in good condition.
Old March 16th, 2014, 05:04 PM   #139
frdboy
frdboy's Avatar
Been working on the frame, the only bad spot I have found is where a PO cobbled on the rear bumper...otherwise it is really solid. Cut off all the extra brackets, rear spring hangers, coil buckets and shock mounts.
The plan is to move the front forward 2" and the rear maybe 2-4". I have the coil buckets moved and back on.
Old March 16th, 2014, 05:25 PM   #140
jhnyquest
goof ball
jhnyquest's Avatar
Nice
Page generated in 0.45415 seconds with 84 queries
