My Early Bronco build - Page 10 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 17th, 2014, 06:44 AM   #181
frdboy
frdboy's Avatar
Got the rear all together
Locker installed
I like to use the Ratech solid pinion spacer.....gets rid of the crush sleeve, and uses shims to set pre-load. Allows you to get some torque on the nut to keep it from backing off.
First shot with a .026" shim was in a little deep
Ended up with a .024" shim, .006" B/L, and 30 In/lbs pinion pre-load
Because the brg sits down in the brake bracket I had to add some spacers to the brg. retainers, I welded some shims I cut up to the backs of the retainers.
Just needs paint!
Old April 17th, 2014, 06:45 AM   #182
nd4spd71
nd4spd71's Avatar
Sexy
nd4spd71 is offline   Reply With Quote
Old April 17th, 2014, 06:58 AM   #183
Lousypirate
Whoop Whoop
Lousypirate's Avatar
I have a question... Is there any rhyme or reason to caliper location on the rear axle?
I see them at all different angles relative to the rotor face.
The Kernel (46 CJ2a)
Wow, i would lick those...
Lousypirate is online now   Reply With Quote
Old April 17th, 2014, 07:55 AM   #184
Bleeder at the highest point?
Old April 17th, 2014, 07:59 AM   #185
frdboy
frdboy's Avatar
I am not sure why they put them where they do.....I would thing packaging and how the E-brake cables need to be routed would be up on the list.
Old April 17th, 2014, 08:05 AM   #186
Lousypirate
Whoop Whoop
you can flip the caliper to the other side to flip the bleeder. I understand clocking for bleeder position, but not for anything else. I was going to do a disc brake conversion on my 14b and I planned on welding the bracket so the caliper is oriented as high as possible to keep from smashing into things, clocking towards front because it would have been better protected that way (between tire and leaf, breakover of truck would assist in keeping things out of it)
but it all depends on how you think about it I guess.
Old April 17th, 2014, 08:40 PM   #187
frdboy
frdboy's Avatar
Rear frame rails replaced, used some .250" 3" x 3" angle pieces inside the rails to form a inner box and strenghten the joint.
Hope to have the body back from the blaster tomorrow.
Big thanks to my good friend Matt (durasmack06) for the use of his barn all the help!
Old April 18th, 2014, 09:24 AM   #188
frdboy
frdboy's Avatar
Thanks to FORD FLARESIDE, I know have some DOM to build my radius arms
Old April 18th, 2014, 09:32 AM   #189
Lousypirate
Whoop Whoop
Sexy
Old April 18th, 2014, 10:23 AM   #190
frdboy
frdboy's Avatar
Hope mine is as sexy as this!
http://nh.craigslist.org/cto/4411699098.html
Old April 18th, 2014, 10:26 AM   #191
nd4spd71
nd4spd71's Avatar
No chance. Lol
Old April 18th, 2014, 10:59 AM   #192
jbsjunk
Little Member
jbsjunk's Avatar
Never be as baller as that. It oozes class.
Old April 18th, 2014, 12:02 PM   #193
FORD FLARESIDE
Year 2 Griffins Travel
FORD FLARESIDE's Avatar
Old April 18th, 2014, 12:30 PM   #194
Lousypirate
Whoop Whoop
That's a bronco?
Old April 18th, 2014, 10:54 PM   #195
frdboy
frdboy's Avatar
Got the tub back from the blaster....not too bad rust wise, some repair to do in the floors and found some bondo but over all I am happy.
Did a little trimming for the flares
Shot it with some epoxy primer
Old April 18th, 2014, 11:03 PM   #196
xj4life
xj4life's Avatar
Pick a paint color yet?
Old April 18th, 2014, 11:06 PM   #197
frdboy
frdboy's Avatar
nope
Old April 19th, 2014, 04:29 AM   #198
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Looking good Adam!
Old April 19th, 2014, 07:56 AM   #199
sandguy356
bronco built for fun
sandguy356's Avatar
That's going well, what are you doing for radius arms?
Might have to stop over and check them out
sandguy356 is offline   Reply With Quote
Old April 19th, 2014, 04:59 PM   #200
frdboy
frdboy's Avatar
Gonna keep it simple this year and just build off the old ones, extend them back a ways and will be using a 1.25" heim at the frame.
Page generated in 0.48365 seconds with 84 queries
