Carburator rebuild - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 3rd, 2013, 09:26 AM   #1
pizzaman
pizzaman's Avatar
Default Carburator rebuild
Looking for someone with experience to rebuild a carburetor.
Holly Truck Avenger 670. I have a master rebuild kit.
Thanks
pizzaman is offline   Reply With Quote
Old August 3rd, 2013, 09:39 AM   #2
When you take it apart, make sure you know where each adjustment screw was at. IE, idle screw, turn it in half turn at a time till it lightly bottoms out. Usually about 1 1/2 turns. Make sure when you put it back together it's the same. Everything else is just plug & play replacement. Make sure it's clean and you put the new parts in where the old ones came out. You'll be good to go.
Old August 3rd, 2013, 09:47 AM   #3
pizzaman
pizzaman's Avatar
It's been 20 years since I've done one. Don't think I have the patience to do it. Think I might outsource this one.
Old August 6th, 2013, 08:08 PM   #4
pizzaman
pizzaman's Avatar
before carb rebuild
Old August 6th, 2013, 08:10 PM   #5
pizzaman
pizzaman's Avatar
after carb rebuild and blowing out the fuel lines
Old August 17th, 2013, 11:12 PM   #6
chuckles123
chuckles123's Avatar
Sigh i am in need of one also question does your metering plate rattle >< mine does I am wonding if that is problem with my carb or its check valve for the 40deg incline deal .I just can't seam to win with it
chuckles123 is offline   Reply With Quote
Page generated in 0.21956 seconds with 41 queries
