Pulling CJ2A with Tj - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 5th, 2013, 09:36 AM   #61
nickb304
nickb304's Avatar
I am sure you could gut 200# worth of crap out of the tj to get back to your GCVWR. I think it would pull nicer on a dolly than flat towing. I would pull the rear shaft rent a dolly and hit the road.
nickb304 is offline   Reply With Quote
Old August 5th, 2013, 11:51 AM   #62
The pulling part itself shouldn't be too bad. I flat towed my CJ5 behind a couple smaller things, and flat towed my CJ3a behind my lifted XJ, which is the same weight as a TJ, but little extra wheelbase.
Where I ran into problems was the stuff due to flat towing. The CJ3a had issues with brakes dragging, and with the steering not wanting to recenter after turns. That kind of stuff can be a bit hard to handle with the small tow vehicle. Its the what-if's.. those things that seem to go wrong. Especially if you wheel it, and then there's an issue when you try to drag it back. (Say you break some teeth on the ring and pinion, or damage wheel bearings, etc... you can't flat tow that back home)
That can be lessened by a tow dolly, since you can at least get one set of tires off the ground. Its rare to bust the thing so bad that both axles can't turn.
Old August 5th, 2013, 12:01 PM   #63
fdomb
fdomb's Avatar
From my personal experience I wouldn't recommend it. I flat towed mt wife's CJ5 behind my LJ and it was a nightmare. Couldnt go over 55. Got pushed off the freeway 10 times and through 2 intersections by the CJ. Should have brought my Brake Buddy and auxiliary lighting. CJ's battery was only good for 2 hours for emergancy flashers. I would trailer it with the right tow vehicle.
fdomb is offline   Reply With Quote
Old August 5th, 2013, 02:35 PM   #64
PeteC
Get Up and Go
Pulled the TJ with mid 2000's Durango's on 2 seperate occasions. Not bad except stopping. Took a longer distance and effort to stop. (both Durangos had trailer tow setup)
Tested flat towing my TJ behind my Commander. Nope, never again. Slow to moderate speeds were fine. Straight on the highway was fine. 55mph on I696 at the Ryan/Dequindre curves were scary. Back end of the Commander was getting pushed into the next lane. It is a different rear push than you get from say, a boat trailer. Much harder to control. Also, braking was not good, and yes, the Commander was also set up for towing.
I personally might consider trying again if I had a brake buddy in the vehicle I was towing. At least then you can use it to control your back end a bit.
But, you can all do whatever you want. I just hope I am not in the way when something does go wrong.
Oh, and I do not have a tow rig or trailer these days. And before I did I drove my Jeeps up north and wheeled accordingly.
PeteC is offline   Reply With Quote
Old August 6th, 2013, 09:40 AM   #65
swampjeep
Swamp Stomper
swampjeep's Avatar
Personally, I would sell the CJ2A to someone with a truck and trailer,
I just so happen to have a truck and a trailer, please PM my a price.
swampjeep is offline   Reply With Quote
Old August 6th, 2013, 09:41 AM   #66
Immortal
NO RELIGION WAT!
Immortal's Avatar
This option is safer for everyone
Old August 6th, 2013, 10:59 AM   #67
TJJEEP
TJJEEP's Avatar
Send a message via AIM to TJJEEP Send a message via MSN to TJJEEP
We have not heard from the OP in a while. He must have spun out of control crashing into a ditch and died a fiery death while trying to tow his CJ2A.
TJJEEP is offline   Reply With Quote
Old August 6th, 2013, 09:32 PM   #68
kvanleuven
Sorry, I have been recovering in the hospital after rolling my jeep. I tried to pull it all up north and everything was going great but then I decided to stop by my buddies place and hook his bass boat up to the back of the cj2a. Unfortunately, I rolled my TJ/CJ2A/Bass Boat caravan on my way up 75.
kvanleuven is offline   Reply With Quote
Old August 6th, 2013, 09:39 PM   #69
concreteguy82
Yeah Buddy!!
concreteguy82's Avatar
concreteguy82 is offline   Reply With Quote
Old August 6th, 2013, 09:54 PM   #70
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
LMFAO Best post ever.
Old August 7th, 2013, 08:45 AM   #71
swampjeep
Swamp Stomper
swampjeep's Avatar
if the CJ2a didn't receive too much damage I may still be interested, please PM me price and pics.
Old August 7th, 2013, 09:43 AM   #72
Sol Goode
Obama Nation!
Sol Goode's Avatar
Is the bass boat for sale?
thanks
#YOLO
#meballsohard
Sol Goode is offline   Reply With Quote
Old August 7th, 2013, 09:46 AM   #73
Immortal
NO RELIGION WAT!
Immortal's Avatar
You'll be fine flat towing it.
Look what you did!
Old August 8th, 2013, 12:44 PM   #74
87mopar
Web Wheeler :(
87mopar's Avatar
Was there a dune flag on each vehicle and the boat?
"Insert Comedic and or ego boosting quote questioning another members sexual orientation here"
http://www.greatlakes4x4.com/imageho...60bd7ea6d9.gif
87mopar is offline   Reply With Quote
Old August 8th, 2013, 04:29 PM   #75
lbfin88
American Infidel
lbfin88's Avatar
Send a message via AIM to lbfin88
I can say from experience, DON'T DO IT! Please do not attempt to tow another vehicle with a swb TJ.
The tow dolly stayed attached but snapped off at the tongue. On the way to silver lake it slipped on gravel in a construction zone and went outta control.
lbfin88 is offline   Reply With Quote
Old August 8th, 2013, 05:11 PM   #76
ZOMG you shouldn't breathe anymore, someone died once from inhaling something.
Old August 8th, 2013, 07:54 PM   #77
BlooMule
Old School
BlooMule's Avatar
You can tow a CJ with a TJ as long as you aren't getting a BJ
-rw-rw-rw
Old August 8th, 2013, 08:24 PM   #78
fordbronco
the ocean called
fordbronco's Avatar
Old August 8th, 2013, 08:33 PM   #79
Immortal
NO RELIGION WAT!
Immortal's Avatar
Originally Posted by fordbronco View Post
Really? lol
Old August 8th, 2013, 09:02 PM   #80
fordbronco
the ocean called
fordbronco's Avatar
Originally Posted by Immortal View Post
Really? lol
yeah, i was bored lol
Page generated in 0.33316 seconds with 82 queries
