WJ: Hood Won't latch - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 30th, 2013, 12:38 PM   #1
Sandals
Fucking Zen as Shit
Sandals's Avatar
Default Hood Won't latch
2001 WJ.
For some reason the hood will not fully latch, it will catch on the secondary one (that you pull with the lever to open it) but not the main one that keep it fully down.
It has enough travel, i even screwed in the leveling adjusters to make sure.
The latch does not seem to have any fore and aft play in it.
Is there a spring or latch mechanism in the primary that is connected to the interior pull that may be causing issues?
Old July 30th, 2013, 08:29 PM   #2
WACKO1
2000 xj
WACKO1's Avatar
is the release handle loose,if so open hood and look at latch.see the spring if their is a lever with the spring hooked to it is to the left.take a screw driver and push the lever to the right side of vechile and spray with lube
WACKO1 is offline   Reply With Quote
Old July 30th, 2013, 08:33 PM   #3
GREASYHANDS
GREASYHANDS's Avatar
Lube fo sho, then wurk it around with the shaft of your tool. Once it be well lubricated try popping it in again
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old July 30th, 2013, 08:37 PM   #4
cmetzg03
FORMER BULLET CATCHER
cmetzg03's Avatar
That's what she said.
“In my experience, Marines are gung ho no matter what. They will all fight to the death. Everyone of them just wants to get out there and kill. They are bad-ass, hard-charging mothers-fuckers.”
― Chris Kyle, American Sniper
cmetzg03 is offline   Reply With Quote
Old August 4th, 2013, 11:22 PM   #5
X-Rated
Had the same thing goin on with an XJ, took apart, cleaned and lubed, put back together and same prob. I ended up shortening that fat wire that goes from center bracket to latch on the side that wouldnt hook about an inch by bending a "Z" into it. Worked fine then.
Idk if your WJ has the exact same latch set up tho
X-Rated is offline   Reply With Quote
Page generated in 0.22185 seconds with 38 queries
