Impact wrench and air compressor - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 30th, 2013, 11:13 AM   #1
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Default Impact wrench and air compressor
I have an IR 2135 TiMAX 1/2" impact wrench hooked up to a Craftsman 20 gallon 150psi max air compressor. I feel like my gun isn't performing to it's full potential. I usually just turn the compressor to the most psi it will go to.
Is there anyway I can make my wrench perform better? It is an awesome gun, but I feel like it should be more powerful.
Maybe high flow air fittings? I don't know. Any help would be much appreciated.
Old July 30th, 2013, 11:20 AM   #2
EL BURRO
33's is how I roll
EL BURRO's Avatar
Oil with marvel mystery oil z, available from any auto parts store
EL BURRO is offline   Reply With Quote
Old July 30th, 2013, 11:20 AM   #3
EL BURRO
33's is how I roll
EL BURRO's Avatar
Red and black can
Old July 30th, 2013, 11:21 AM   #4
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
If your talking about adding oil to my gun, I just use transmission oil and add it every time I use it.
Old July 30th, 2013, 11:21 AM   #5
Ebs
Look at your air line and fitting sizes.
Old July 30th, 2013, 11:27 AM   #6
Immortal
NO RELIGION WAT!
Immortal's Avatar
IR 2135 TiMAX 1/2" impact wrench:
Average cfm is 5
20 gallon compressor:
SCFM Delivery:
SCFM Delivery At 40 psi: 5.1
SCFM Delivery At 90 psi: 3.8
Old July 30th, 2013, 11:28 AM   #7
fsumotorhead
N8KVB
fsumotorhead's Avatar
It may or may not help you, butmy gun seemed low on power awhile back. I tightened all the bolts that hold the case halves together (nose to body), works strong as ever.
Old July 30th, 2013, 11:30 AM   #8
Immortal
NO RELIGION WAT!
Immortal's Avatar
Hmm....I have seen this happen on other types of air tools like an air hammer, but never thought it could happen to an impact.
Old July 30th, 2013, 11:30 AM   #9
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
I'll check the bolts when I get home.
And I actually think it's a 33 gallon, not a 20. Just going off the top of my head right now.
Old July 30th, 2013, 12:07 PM   #10
Mr.Green
I can levitate!
Mr.Green's Avatar
You might try to lay some new pipe in your garage.
Old July 30th, 2013, 01:28 PM   #11
cerial
Direct Drive FTW
cerial's Avatar
Do you have any kind of dryer/inline oilier?
When is the last time you drained the water from your tank?
Old July 30th, 2013, 02:36 PM   #12
Average cfm is 5
SCFM Delivery:
Yeah, but that only matters if he's running it continuously.
If its the compressor, then it would run fine when running off the tank, and then low on power when the compressor is running.
If its the line/fittings, then it would run low on power all the time.
You might be limited also by the flow rate of the regulator itself that is usually on the compressor.
Old September 30th, 2013, 12:37 PM   #13
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Just a little update. I had a swivel air connector on my impact wrench. It seemed a little loose at the swivel, so I took it off and now it's just the male 1/4" connector. Hooking it up to my air compressor and running it at 90psi, I can say it runs much better and seems a lot more powerful. I just ordered a high flow air connector so hopefully that will help it out a little more.
Old September 30th, 2013, 01:47 PM   #14
Mr.Green
I can levitate!
Mr.Green's Avatar
Did you at least try to lay some new pipe (air pipe) in your garage?
Old September 30th, 2013, 05:48 PM   #15
wilesin
10ptbuck
wilesin's Avatar
Strike two.
wilesin is offline   Reply With Quote
Old September 30th, 2013, 08:15 PM   #16
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
Moar power!
I'm the man in White.
Old September 30th, 2013, 08:23 PM   #17
michigan maniac
michigan maniac's Avatar
I've seen the quick connect ends go bad also and restriction air flow
Old September 30th, 2013, 08:24 PM   #18
creeping death
I'm that guy.
creeping death's Avatar
Originally Posted by wilesin View Post
Strike two.
Old September 30th, 2013, 08:47 PM   #19
BlooMule
Old School
BlooMule's Avatar
If you are using 1/4" air hose step up to 3/8".
Flow is the name of the game.
-rw-rw-rw
Old October 1st, 2013, 05:31 AM   #20
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
He should know bigger pipe is better
Silver Bullet is offline   Reply With Quote
Page generated in 0.37696 seconds with 82 queries
