Running rough seems to be starving for fuel? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 30th, 2013, 02:31 PM   #21
camoII
camoII's Avatar
*ground straps.
camoII is offline   Reply With Quote
Old July 31st, 2013, 05:26 AM   #22
camoII
camoII's Avatar
Coolant temp sensor! Can't believe that's what it was but seems to be it. Thanks for all the help guys.
Old July 31st, 2013, 08:01 PM   #23
ljense8
Web Wheeler
ljense8's Avatar
Fwiw, there should be two coolant temp sensors. One is for the gauge and one is for the computer. You changed the one for the computer, located on the intake. This one is listed as a coolant temp sensor at parts stores. The other is located on the head on the driver's side. This one controls the gauge and is called a coolant temp SENDER. Just thought I'd let you know in case you wanted to get your gauge working too. This is also assuming 92's are set up the same as my 91. Hopefully it helps, sorry for babbling if it doesn't.
ljense8 is offline   Reply With Quote
Old August 1st, 2013, 05:33 AM   #24
camoII
camoII's Avatar
I found that out, I got the coolant temp sensor and thought it was the one in the head but it was different, went to three different parts stores and they were all the same and thought wtf why is mine different?? Then I found out I was looking at the wrong one! Haha oh well it's running at least.
Old August 1st, 2013, 05:58 AM   #25
ljense8
Web Wheeler
ljense8's Avatar
Glad to hear it's running. I had the same problem with mine when I bought it. The PO never installed the coolant temp sensor when he swapped a new engine in, and it ran like crap. You can check the codes with a paper clip if you want. Go to ck5.com and search it. There is a good article there with a diagram and a list of code definitions that will help you. It only takes about 1 minute to read a code.
Old August 1st, 2013, 06:09 AM   #26
camoII
camoII's Avatar
Well I may have to read the codes. I thought it was running better but this morning on the way to work it started running bad again. When I'm sitting at a light idling it will be fine, I go to step on the gas and it sputters and almost stalls out. Actually did stall one time but fired back up. This is starting to get really old! No check engine light is on right now.
Old August 1st, 2013, 06:22 AM   #27
camoII
camoII's Avatar
I looked at how to read the codes but I don't understand how I know what code I have, the engine light flashes so many times and that's the number code I have?
Old August 1st, 2013, 06:51 AM   #28
camoII
camoII's Avatar
Ok I have a code 15 an 43. 15 is low temp indicated at engine coolant temp sensor. I just put a new sensor in it so I don't understand why that's happening.
43 is low voltage at electronic spark timing circuit.
How do I go about fixing that?
Old August 1st, 2013, 09:14 AM   #29
Toyfish
Toyfish's Avatar
sounds like a igniting module its inside the distributor pretty easy to change pull the cap and rotor and its mounted to the distributor with two small screws
Old August 1st, 2013, 09:16 AM   #30
firehawk
Live Action!
firehawk's Avatar
Plug those into google, I am sure there is tons to read.
Old August 1st, 2013, 09:35 AM   #31
muddychevy22
lifted jeep
muddychevy22's Avatar
did u check the coil
muddychevy22 is offline   Reply With Quote
Old August 1st, 2013, 09:41 AM   #32
camoII
camoII's Avatar
Didn't check the coil. I did google and sounds like the icm or possibly the computer is taking a shit.
Old August 1st, 2013, 05:17 PM   #33
ljense8
Web Wheeler
ljense8's Avatar
Usually when the computer goes, it's instant, not gradual, plus it's quite rare. If that is the case(which I doubt) I have a spare computer I'd sell you cheap. It's probably a coil or igniting module. Keep us informed and good luck.
Old August 1st, 2013, 05:42 PM   #34
camoII
camoII's Avatar
The ignition module goes bad slowly? I've had one go bad but it was instant.
Old August 1st, 2013, 10:21 PM   #35
ljense8
Web Wheeler
ljense8's Avatar
Probably instant there too. One thing you could try is reset your computer. Disconnect the negative on your battery for a few minutes and then reconnect it. This will clear all learned data from you computer, including codes, and let it "learn" your engine parameters fresh. This will probably fix the low temp code, but not the voltage.
Old August 2nd, 2013, 05:03 AM   #36
camoII
camoII's Avatar
I did reset the computer a few times and it seemed like it helped to begin with then about 2 minutes later it started running bad again.
Old August 2nd, 2013, 05:06 AM   #37
camoII
camoII's Avatar
Gonna try a coil next I guess.
Old August 2nd, 2013, 05:08 AM   #38
camoII
camoII's Avatar
How about that electronic spark control module?
Old August 6th, 2013, 06:30 AM   #39
camoII
camoII's Avatar
Well after replacing pretty well everything I possibly could there is no improvement so I went and bought a 6.5 turbo diesel donor truck to put it all in my truck.
Old August 8th, 2013, 04:29 PM   #40
montecarlo33
The Violator
montecarlo33's Avatar
I just bought a 94 k1500 with a 350 tbi for cheap and its doing the same thing, only mine will only blink out code 22 which is low voltage to tps. However tps is brand new. I will be working with mine to try and figure something out, I will be testing the egr system tonight along with the intake gasket with carb clean.
Page generated in 0.57759 seconds with 83 queries
