77 cj5 amc 360 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 28th, 2013, 03:56 PM   #1
Hollistud23
Default 77 cj5 amc 360
1977 Jeep CJ5.
First off it sits on an international scout frame. Body swap was done before I got it and looks to have been a decent job. No major concerns. Being as old as it is, it has it's quirks. Would take a few things to make an everyday driver. Things such as installing a track bar, just to help it's handling on the road. But is fine if u can just deal with it. Recently found out that there is no windshield wiper motor. And that for some reason, I believe it's somewhere in the wiring, that the heat and defrost options don't work. It runs great. It has the Amc 360 and is mounted to a 3 speed manual. Very fun to drive
Looking for 2500* or a trade for a more suitable daily driver. 4x4 preferably
231-679-5545
Hollistud23 is offline   Reply With Quote
Old July 31st, 2013, 05:17 PM   #2
Hollistud23
Hump day bump
Old July 31st, 2013, 06:00 PM   #3
dmcjeep
dmcjeep's Avatar
Any work done to the 360? Intake, cam, headers? Original 74 Jeep transmission?
dmcjeep is offline   Reply With Quote
Old July 31st, 2013, 06:51 PM   #4
Hollistud23
Holley carb. And headman headers. And both motor and transa came out of a 74 scout
Old August 26th, 2013, 04:29 PM   #5
Hollistud23
Bump.
Old September 1st, 2013, 12:17 PM   #6
79CJ5 Renegade
79CJ5 Renegade's Avatar
How are the frame and tub?
79CJ5 Renegade is offline   Reply With Quote
Old September 1st, 2013, 12:19 PM   #7
Hollistud23
Frame is great. Tub is by no means perfect. Rust here and there but not junk.
Old September 2nd, 2013, 10:15 AM   #8
Hollistud23
Old September 2nd, 2013, 10:54 AM   #9
amc78cj7
amc78cj7's Avatar
AMC 360 in a scout?
Engines
Engine produced by International Harvester:
IH 4-152** (See note below on this engine)
IH 4-196** (See note below on this engine)
IH V-266
IH V-304 (Note: This is NOT the same engine as the AMC 304 V8)
IH V-345
IH V-392 (Note: Based on the same block as the 345)
Built by American Motors Corporation
AMC 6-232
AMC 6-258
AMC "V400" (some 73/74 pickups and travelalls had this, the AMC 401, installed as there was a shortage of the V-392 engines.
To tell the AMC engine from IH's own V8s, look at the thermostat housing. AMC is round. IH is rectangular. There are other differences but this is the quickest method.
Built by Nissan
Nissan SD33 (diesel) (naturally aspirated)
Nissan SD33T (turbo diesel—1980 only)
International offered the Scout with a variety of engines over its years of production. The Scout 80 (1961–1965) had the gasoline-powered 152 four-cylinder as its standard engine. From 1965 to 1971 (Models 800, 800A, and 800B), engine options were the gasoline-powered 196 four-cylinder, AMC 232 six-cylinder, 266 V-8, and the 304 V-8. A turbocharged version of the 152 four-cylinder engine was offered from 1965 to 1967.[citation needed]
It is also worth noting that International Harvester was not really geared up for the production of a four-cylinder engine, as was seen in the 152 and 196 engines. Consequently, they simply cut off four of the cylinders and sold these two engines as half of the V-304 and half of the V-392. This is why these engines are in an inline, yet slanted formation, half of a V-8. They became small engines with a great deal of torque, excellent cooling because the block contained water channels originally designed for the larger engines, all while getting quite acceptable fuel economy. The Scouts with the 196 engines easily achieved 20 miles per gallon.
There are rumors that a few early Scouts left the factory with Perkins diesel engines, but these would have been special-order trucks and not a standard option. The Scout II (made between 1971 and 1980) had the following engine options: the 196 4-cylinder, 232 6-cylinder (early production), 258 6-cylinder (later production), 304 V-8, and 345 V-8. At the time, International did not manufacture a diesel engine small enough to be used in the Scout, and so starting in 1976 used the Nissan SD33 diesel engine as a diesel option. This engine was replaced by the Nissan SD33T turbodiesel engine in 1980.
I'm not quoting idiots who promote unsafe recovery strap techniques anymore. :miff:
amc78cj7 is offline   Reply With Quote
Old September 2nd, 2013, 11:20 AM   #10
Hollistud23
This is what I was told. I did not do the work on it. It very well may have been out of a gremlin or another Amc model. I'm not trying to trick anyone, but I should have probably checked into it more before posting.
Old September 3rd, 2013, 02:17 PM   #11
Hollistud23
Picture of motor
Old September 15th, 2013, 06:30 PM   #12
michigan maniac
michigan maniac's Avatar
Top? And doors?
Old September 15th, 2013, 06:32 PM   #13
Hollistud23
There are no doors and only a bikini top. So basically no top.
Old October 5th, 2013, 03:17 PM   #14
Hollistud23
Bump. Have some leads on some tops if ur interested.
Old October 5th, 2013, 09:01 PM   #15
michigan maniac
Any interest in a 2003 focus ?
Old October 5th, 2013, 09:03 PM   #16
Hollistud23
No thanks. Would like a pickup. I have some wood hauling I need to do. But thank u for the offer
Old November 4th, 2013, 10:57 AM   #17
Hollistud23
Taking cash offers. Don't be bashful.
Old November 4th, 2013, 09:27 PM   #18
michigan maniac
I've got a 6.5 diesel pickup ??
Old November 4th, 2013, 09:30 PM   #19
Hollistud23
Pm sent
Old November 12th, 2013, 08:48 AM   #20
Hollistud23
Page generated in 0.35574 seconds with 84 queries
