2000 jimmy day time running lights wont shut off (at all) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 28th, 2013, 03:36 AM   #1
1BigXJ
The Outlaw
1BigXJ's Avatar
Default 2000 jimmy day time running lights wont shut off (at all)
Got a 2000 jimmy the other day, got it home and the headlights wouldn't shut off, tried turning the switch on and off, tried bypassing the daytime running lights by pressing the dome override button 4 times, it dings but lights stay on anyway, tried pushing down the parking brake, still on, disconnected the battery in hopes it would reset but as soon as I hook the battery back up the lights are one, I haven't tracked down the relay because I read that the relay that runs them also runs something , I've also heard of people popping the passenger dash speaker and replacing the censor with a resistor but I wouldn't even know where to start or even get the right resistor, any help would be awesome
1BigXJ is offline   Reply With Quote
Old July 30th, 2013, 07:55 PM   #2
1BigXJ
The Outlaw
1BigXJ's Avatar
Any ideas?
Old July 30th, 2013, 08:13 PM   #3
GREASYHANDS
GREASYHANDS's Avatar
Pulling the drl relay and checking what terminals have battery positive voltage would be a start to your quest.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old July 31st, 2013, 08:22 AM   #4
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
did you make sure it has a constant 1.21 gigawatts?
Old July 31st, 2013, 09:34 AM   #5
IFS SUCKS
I like trees
IFS SUCKS's Avatar
2000 GMC Truck Envoy 4WD V6-4.3L VIN W
Vehicle » Lighting and Horns » Daytime Running Lamp Relay » Locations
•Locations
In the Under hood Fuse Block
Taped to the body harness near the breakout for the rear washer hose
IFS SUCKS is offline   Reply With Quote
Old July 31st, 2013, 07:09 PM   #6
1BigXJ
The Outlaw
1BigXJ's Avatar
Found the relay, all it was labeled was drl, pulled it lights went off, started it checked everything, seems fine now, just gotta turn the lights on by the switch, no big deal, thanks everyone
Old July 31st, 2013, 08:19 PM   #7
GREASYHANDS
Did you find the problem?
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old July 31st, 2013, 09:59 PM   #8
1BigXJ
The Outlaw
1BigXJ's Avatar
No not exactly, could replace the relay to see if it was bad or whatever but just removing it works fine for me
Old August 2nd, 2013, 05:28 AM   #9
1BigXJ
The Outlaw
1BigXJ's Avatar
Took the jimmy out a couple nights ago after pulling the relay and the headlights turn on now with low light and I can bypass them with the dome override button and shut them off so pulling the relay really worked I guess lol
Page generated in 0.23510 seconds with 50 queries
