So should a 5.7 injection system look like this? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 27th, 2013, 05:10 PM   #1
Shotgun
I only wheel with boats.
Shotgun's Avatar
Default So should a 5.7 injection system look like this?
I think it may have been killed with fire.
Dizzy gear smoked, had a few good back fires while trying to reset the timing after new dizzy install. Now I see moar monies spent in the future.
ID:	108628   Click image for larger version
ID:	108629   Click image for larger version
Old July 27th, 2013, 05:21 PM   #2
pigfat
GONE COMMANDO
pigfat's Avatar
Yes, many, many of them have work done looked exactly the same inside. Are you changing one of the poppet valves?
Sent from my XT907 using Tapatalk 2
pigfat is offline   Reply With Quote
Old July 27th, 2013, 05:23 PM   #3
dreezy
Haggard Fab
dreezy's Avatar
shit'll buff out
Old July 27th, 2013, 05:28 PM   #4
Shotgun
Shotgun's Avatar
I was having a 5/7 cylinder misfire. It was running quite rich, the intake was wet. I'm going to hook the fuel lines up and connect the tps and roll it over to see if there is a leaker. Of course with the dizzy disabled.
Old July 27th, 2013, 07:32 PM   #5
pigfat
GONE COMMANDO
pigfat's Avatar
You will need to distributor connected, just unhook the high tension lead from the ignition coil and turn it over, but those are poppet valves not like a traditional injector so you may have a difficult time seeing if they're operating properly chances are you have a sticky injector on 5&7 if the problem is an injector at all
Old July 27th, 2013, 07:35 PM   #6
skife
skife's Avatar
do yourself a favor and upgrade to the MFI setup that GP sorensen makes, it runs around $320-350 p/n: 800-1513N
Old July 27th, 2013, 07:57 PM   #7
Shotgun
Shotgun's Avatar
I just wanna see how bad the lines are pissing. I'm guessing that with the burn marks on them they will be squirters all inside the intake before it even hits the end.
Old July 28th, 2013, 07:38 PM   #8
Shotgun
Shotgun's Avatar
3 out of 8 were streamers. New system installed and now runs like a raped ape. :)
Old July 28th, 2013, 07:40 PM   #9
pigfat
GONE COMMANDO
pigfat's Avatar
Nice work
Old July 28th, 2013, 07:43 PM   #10
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
i was just about to say i have a spider in barn (i think) you could of had
Old July 28th, 2013, 08:22 PM   #11
Shotgun
Shotgun's Avatar
Thanks, I just spent 300 on these....lol
Page generated in 0.18470 seconds with 56 queries
