Whats next? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 25th, 2013, 09:25 PM   #1
Carbon
Yooper
Carbon's Avatar
Default Whats next?
Here is what I have so far. I think the rear is good to go other then getting a drive shaft made up. Take a look at the front and tell me what you think as far as my pinion angle. Do i just need a 4* shim on my perch?
What information am I going to need for getting drive shafts made up, say from tom woods or the like.
Carbon is offline   Reply With Quote
Old July 26th, 2013, 08:49 AM   #2
302sploder
302sploder's Avatar
when tom woods made my rear shaft, they asked me all the measurements you have up there, what type of suspension you're running, and what u-joints you want.
they will tell you if it won't work, suggest a tube diameter and a spline type.
they're very informative and i'd highly recommend giving them a call.
looking at you pictures again, they will want the distance between the faces of your yokes, not the bottom of the u joint surface.
302sploder is offline   Reply With Quote
Old July 26th, 2013, 04:02 PM   #3
Carbon
Yooper
Carbon's Avatar
Sounds good. I will get that information. Anything else I should know or have ready? What can I expect to pay for a pair of drive shafts?
Old July 27th, 2013, 05:29 PM   #4
littletrucker
I'd hit that
littletrucker's Avatar
You have a good measurement of the length at ride height. I would say the more important numbers you would need would be the length at full droop and sitting on the bump stops. This will probably be a determining factor in the price to see if you need a long travel spline setup.
As far as the rear goes the angles should be the same (non cv application) But the front looks very close if you plan on running a cv style shaft (you basically want the the axle yoke pointed at the case yoke.
Old July 27th, 2013, 08:01 PM   #5
Carbon
Yooper
Carbon's Avatar
Thanks for the info!
Page generated in 0.20426 seconds with 38 queries
