why not a ring gear spacer? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 25th, 2013, 10:30 AM   #1
joe_jeep
welfare wheeler
joe_jeep's Avatar
Default why not a ring gear spacer?
the dana 44's in tj rubicons can only be geared down to 5.13.
the 42rle in them has a .69 overdrive ratio, and uses alot of power to spin it.
many guys run 5.13's on 33" tires, and it works well.
i can get standard gears for the d44 in 5.89, that would be perfect for 37's
i have found 2 guys running 5.89's on rubicon lockers with ring gear spacers.
the rubicon wont see any serious abuse, mild trails and street only.
ring gear spacers are not uncommon in some other axles.
i already have selectable lockers, why not run them?
are ring gear spacers that bad?
opinions?
thx
Old July 25th, 2013, 02:49 PM   #2
joe_jeep
welfare wheeler
joe_jeep's Avatar
been looking around, used to be more common in the jaguar and vette crowd to put 4.10's on their 3.73 and down diffs.
broken 44 gears can be shaved to become a spacer. its been done b4.
Old July 25th, 2013, 03:25 PM   #3
in2deep
Hole tester
problem with spacers is that its now only the bolts driving the carrier and not a interference fit that the carrier and ring gear have, I have seen problems with the bolts backing off and egging holes out
Old July 25th, 2013, 03:37 PM   #4
joe_jeep
welfare wheeler
joe_jeep's Avatar
thats a good point! i was under the impression the spacer was about .25 inches tall.
how tall is the lip the ring gear rides on the inside edge of the carrier?
if its under the height of the spacer, i could see the problem for sure!
what about tacking the spacer to the carrier to limit movement? or even tacking all 3 together? bad idea?
it is done on dana 30's 35's and 60's, what makes a 44 so different?
Old July 25th, 2013, 03:45 PM   #5
Tweeternpi
Tweeternpi's Avatar
http://www.jantz4x4.com/jantz.php?p=home
Check this place out. Been looking at them to upgrade my Rubicon Axles in mine.
Tweeternpi is offline   Reply With Quote
Old July 31st, 2013, 11:00 PM   #6
4x4xdodgeman
Send a message via Yahoo to 4x4xdodgeman
I have ring gear spacer in my axles for over 35years no problems. (d60) but back in late 1970s thay did make spacers for dana 44 to. if installed right no problems.
4x4xdodgeman is offline   Reply With Quote
Old August 1st, 2013, 09:03 AM   #7
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Do they make "thick cut" d44 gears?
I am running the thick gears in my 60.....no need to change carrier, no spacer
Old August 1st, 2013, 09:08 AM   #8
Lousypirate
Whoop Whoop
Lousypirate's Avatar
Subbed. Learned something new today.
The Kernel (46 CJ2a)
Wow, i would lick those...
Lousypirate is online now   Reply With Quote
Old August 1st, 2013, 09:33 AM   #9
redhead_823
redhead_823's Avatar
They do make thick d44 gears, but I've only seen them up to 5.13.
redhead_823 is offline   Reply With Quote
Old August 1st, 2013, 10:20 AM   #10
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
I remember the tj rear rubi lockers are junk and on 37's would make me want to change it anyway. Sell the factory lockers to someone on stock stuff and upgrade to the correct ratio lockers.
Old August 1st, 2013, 10:26 AM   #11
Freak
Wheelin the HD
Freak's Avatar
My fried runs a spacer in his 84 Monti Carlo 10bolt, runs 13's just fine no issues for 2 years.
Old August 2nd, 2013, 03:21 PM   #12
joe_jeep
welfare wheeler
joe_jeep's Avatar
changing lockers is a possibility. i would like to keep my selectables, and not pay for new arb's though. im still looking at options. hicks used to sell a ring gear spacer for dana 44's.
it has been done.
Page generated in 0.36697 seconds with 59 queries
