SAS s10 question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 24th, 2013, 11:05 PM   #1
jessezipper
Default SAS s10 question
Ok so I'm doing a SAS on my 93 s10 blazer, I'm attaching a picture and wondering if I need to remove the crossmember that seems to protect the steering.. I've done a google search and some have and most don't.. Just wondering .. I plan to run a gm 10 bolt full width up front and I'm running leafs Click image for larger version
jessezipper is offline   Reply With Quote
Old July 25th, 2013, 12:42 AM   #2
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Trim the rearward facing lip and move on. Or if that doesn't give you enough room, weld on a new crossmember THEN cut off the old one. If you do this part backwards you'll be screwed
Old July 25th, 2013, 01:10 AM   #3
deerebowtie
Unchained
deerebowtie's Avatar
another option would be dakota springs and an astro van steering box. - it would shove that axle 10" forward of where you have it now.
Old July 25th, 2013, 01:25 AM   #4
kkodet
kkodet's Avatar
Yup
Old July 26th, 2013, 12:53 PM   #5
jessezipper
Looks like ill trim the lip and tack everything up this weekend. Hopefully have the axle under too
Page generated in 0.14319 seconds with 39 queries
