CJ: Exhaust manifold Gasket - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 22nd, 2013, 08:53 AM   #1
TimHansen
78 and 83 cj-7's
TimHansen's Avatar
Default Exhaust manifold Gasket
'78 304. Going back to stock manifolds. What gaskets should I get, and should I use some type of gasket sealer, if so what brand.
Studs or bolts also.
Thanks
TimHansen is offline   Reply With Quote
Old July 24th, 2013, 10:34 AM   #2
Outdoors
Field Repairs
Outdoors's Avatar
It depends on how your pipes are built, and are you installing all the original parts. The factory exhaust used flared pipes, which require a donut. On the passengers side there was a heat riser, which required a flange gasket between the manifold and it, and then a donut below where the pipe attached.
If you are like most of us that have pipes bent, they will not be flaring them, so you will be using a flange gasket between the pipe and the manifold. You can look around for a quality flange gasket, but I have found that muffler shops sell the best you can get. They have a style that has a screen mesh in them with a metal center ring. I have never had one fail.
When you install these, you do need to seal them with Permatex High-Heat Red RTV.
I have always removed the studs and installed grade 8 bolts with grade 8 washers. I never re-use them. It's a minor cost compared to messing with the old studs.
Outdoors is offline   Reply With Quote
Page generated in 0.24351 seconds with 29 queries
