Shocks - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 21st, 2013, 06:32 PM   #1
Carbon
Yooper
Carbon's Avatar
Default Shocks
Put 3/4 ton axles (dana44 front, corp 14 rear) under scout II chassis and scout II springs. What do i need to measure for shocks? Going to have new shock mount locations.
Carbon is offline   Reply With Quote
Old July 21st, 2013, 07:09 PM   #2
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
I would pull the spring packs apart and install only the main leaf. I would then cycle the suspension to figure out your droop and uptravel. From there you can figure out the height of the bump stops, length of shocks and driveshaft lengths.
Old July 21st, 2013, 07:44 PM   #3
Carbon
Yooper
Carbon's Avatar
Can i do this with the leaf packs together or is it necessary to pull them apart?
Old July 21st, 2013, 08:01 PM   #4
boggin-machine
boggin-machine's Avatar
Ill them apart. Much easier to cycle in the garage this way
Old July 22nd, 2013, 08:22 AM   #5
Carbon
Yooper
Carbon's Avatar
Old July 22nd, 2013, 09:26 AM   #6
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
What we've done in the past is to drive up a ramp until you almost pull a tire. Then measure full extended on the one side and full bump on the other. This works best if you know basically where you plan to put the shocks.
JohnnyJ is online now   Reply With Quote
Old July 22nd, 2013, 04:07 PM   #7
Carbon
Yooper
Carbon's Avatar
Sound good. Thanks.
Old October 9th, 2013, 11:55 AM   #8
Carbon
Yooper
Carbon's Avatar
Can I use a fork lift or tractor and do this out side with out pulling the packs apart?
Old October 11th, 2013, 04:02 AM   #9
yyj87
yyj87's Avatar
Yes
yyj87 is offline   Reply With Quote
Page generated in 0.17248 seconds with 50 queries
