What drive shafts? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 19th, 2013, 08:33 PM   #1
Carbon
Yooper
Carbon's Avatar
Default What drive shafts?
Scout II with dana 44 front, corporate 14 bolt rear from 79 3/4 ton chevy. Am i looking at custom drive shafts ir is there something available? This is strickly off road and could build my own if i had to.
Carbon is offline   Reply With Quote
Old July 20th, 2013, 05:49 AM   #2
Gonna say yes.
Drive shafts are configured based on;
Fully extended length.
Fully retracted length.
Size of u-joint at front.
Size of u-joint at rear.
Amount of droop determines if you can do it with a single or double cardan joint. (commonly called CV joint)
The only way to determine what fits is to crawl underneath and take all the measurements.
Old July 20th, 2013, 06:58 AM   #3
Carbon
Yooper
Carbon's Avatar
Thanks.
Old July 20th, 2013, 06:58 AM   #4
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Gonna say yes.
This.
Once you get that all figured out hit up your local junkyard for the parts you need then build the shafts yourself. If you take your time you can get them plenty straight enough for a trail rig.
Old July 20th, 2013, 09:09 AM   #5
Carbon
Yooper
Carbon's Avatar
Sound good. Thats my plan. Thanks.
Old July 20th, 2013, 10:04 AM   #6
19602
Gonna say yes.
How do you determine which type of driveshaft from the drop? Is there a set of numbers or a math equation?
19602 is offline   Reply With Quote
Old July 20th, 2013, 10:50 AM   #7
Yeah but I can't tell you what it is.
Old July 20th, 2013, 11:01 AM   #8
Carbon
Yooper
Carbon's Avatar
Hahaha
Page generated in 0.28674 seconds with 47 queries
