rear disc brake swap question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 19th, 2013, 08:37 AM   #1
Sandster
Default rear disc brake swap question
I just swapped in an 8.8 in my 03 TJ and wondering if i need to do anything to the proportioning valve. Someone told me no and some had said i do. Anyways what do i need to do and where is said valve?
Sandster is offline   Reply With Quote
Old July 19th, 2013, 09:55 AM   #2
JayBmeyer
JayBmeyer's Avatar
I don't know if this helps or not. But I had a Ranger and swapped a drum brake 8.8 for a disc brake 8.8 out of a Explorer and did not have any problems with brakes at all. So I don't think you should have a problem.
JayBmeyer is offline   Reply With Quote
Old July 19th, 2013, 11:08 AM   #3
skife
skife's Avatar
Didn't on my 91 xj
Old July 19th, 2013, 11:36 AM   #4
itselliott
itselliott's Avatar
I added disc brakes to my rear D60 ( '79 J20) no other changes .......no noticeable problems as yet.
Old July 19th, 2013, 01:40 PM   #5
skife
skife's Avatar
i know a few of the sites that talk about 8.8 swaps tell you "you may or may not need a new proportioning valve" i never bought one, my rear brakes always worked good.
Old July 19th, 2013, 04:38 PM   #6
yyj87
yyj87's Avatar
How I understand this situation: (I could be wrong)
Drums require less pressure to operate, a factory prop valve regulates pressure to the rear. So when swapping discs on they will still see pressure and work but work better when pressure to both front and back are equal.
I run an open block.
yyj87 is offline   Reply With Quote
Old July 19th, 2013, 05:58 PM   #7
WACKO1
2000 xj
WACKO1's Avatar
What if you have ABS, will they work right
WACKO1 is offline   Reply With Quote
Old July 19th, 2013, 07:13 PM   #8
Dylan
Dylan's Avatar
i swapped disks into the back of my 02 TJ D44. I pulled the plunger out of the PV and pulled a rubber seal. There are directions online. It works great for me.
Old July 20th, 2013, 01:29 PM   #9
yyj87
yyj87's Avatar
This is exactly what I did. Improved stability while standing on the brake pedal.
It seemed to shuffle a bit before I gutted my prop. Valve.
Page generated in 0.27500 seconds with 50 queries
