help please on 01 dodge ram torque spec - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 18th, 2013, 03:09 PM   #1
CHEROKEEMUDMAN01
mellow yellow
CHEROKEEMUDMAN01's Avatar
Default help please on 01 dodge ram torque spec
I have a 2001 dodge ram 2500 Cummins 2wd pu. I have to put a new bearing on front the setup is basically a unit bearing. it has a spindle in the center with a nut that is a 1 time use only nut that holds bearing ion place and is 1 11/16 in size. anyone know the torque spec for that nut. I have check at 2 autoparts stores, the teardown book I have and called the dealer which was a waste of time and still no idea. autozone website says 280 ftlbs but that don't sound right at all. thank you for any info.
Last edited by CHEROKEEMUDMAN01; July 18th, 2013 at 03:27 PM. Reason: spelling error
CHEROKEEMUDMAN01 is offline   Reply With Quote
Old July 18th, 2013, 03:13 PM   #2
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
1. why is this is the Ford Tech forum?
2. google it
Old July 18th, 2013, 03:19 PM   #3
hondadirtracer
Skymaster
hondadirtracer's Avatar
2. google it
and 3. There is no g in Cummins
hondadirtracer is offline   Reply With Quote
Old July 18th, 2013, 03:26 PM   #4
CHEROKEEMUDMAN01
mellow yellow
1.I clicked on dodge forum but work computer is slow so page must have not been done loading.
2. I did search on internet b4 I made this post and haven't had any luck.
3.sorry about the spelling error.
oh and
4. not helping guys but thank you for your 2 cents lol
Old July 18th, 2013, 03:32 PM   #5
CHEROKEEMUDMAN01
mellow yellow
I had a prob trying to find correct unit style bearing but the one that's on this truck is listed as a 1 ton front not the 3/4 ton front.
Old July 18th, 2013, 03:40 PM   #6
wave_crusher
I'll Direc your TV
oh and
After 10 seconds searching
280 ft lbs
Old July 19th, 2013, 11:47 AM   #7
CHEROKEEMUDMAN01
mellow yellow
well after an hour of searching I have seen 3 different answers. I have seen 110ft lbs, 180ft lbs, and autozone at 280ft lbs. so since there was such a wide range of torque specs I was hoping someone knew the correct spec. like I said I had already looked on internet. and 280ft lbs seems way to much for a zinc nut plus prob need a 10ft cheater bar for that much torque so I am finding that one hard to believe but could be wrong.
Old July 19th, 2013, 12:42 PM   #8
wave_crusher
I'll Direc your TV
I don't know where you got 110, but 180 is for 4x4, and the multiple places that had 280 all said that a cheater bar was needed. It would also explain why the nut is a one time use only. That is a lot of torque on one nut
Old July 19th, 2013, 12:54 PM   #9
PinItToWinIt
PinItToWinIt's Avatar
I always set them to 280, any less and the bearing will go bad agin. Incorrect toqure is the main reason they go bad after replacement. I just a 1/2in torque wrench that goes to 200 ft pounds with a 4 foot cheater pipe and put my weight on it.
PinItToWinIt is offline   Reply With Quote
Old July 19th, 2013, 12:59 PM   #10
CHEROKEEMUDMAN01
mellow yellow
thank you guys very much . I guess 280ft lbs it is just wanted to make 100% shure before I did it since that bearing was so much money. I appricate the info and the help. I think this will be the most I have ever torqued anything lol
Page generated in 0.37670 seconds with 53 queries
