TJ: chattering under load - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 16th, 2013, 08:31 PM   #1
skier206
skier206's Avatar
Default chattering under load
Help, I have a 2000 TJ that was making a funny noise so after some exploring I found the the front track bar was loose ( 6" long arm BDS 10 mounths old ) so I removed it to check the hole and reinstalled, then checked the fluids in the diffs topped off the rear. Then left for a ride and between 25 and 45 mph the dash, steering wheel chattered so bad. I have checked and it only does it under load because going down hill off the skinny pedal it does not do it. so any help that anyone can provide would be very helpful. It does have a 6" LA with 35" tires air lockers front and rear with 4:56 gears. If there is anything that it might have missed let me know. Thanks in advance.
skier206 is offline   Reply With Quote
Old July 19th, 2013, 08:08 PM   #2
hurray for jeeps!
hurray for jeeps!'s Avatar
U joints On driveshaft? Mine does the same thing but mostly during take off or under a load and I suspect that's what my deal is
hurray for jeeps! is offline   Reply With Quote
Old July 19th, 2013, 08:12 PM   #3
robbietap
Manual?
robbietap is offline   Reply With Quote
Old August 26th, 2013, 07:38 AM   #4
2trackin
Jeepster
I have pretty much the same setup. Check your driveshaft. Maybe a balancing weight came off. Check motor and transmission mounts. Jack the thing up and unload the suspension and check for excess play.
2trackin is offline   Reply With Quote
Page generated in 1.86208 seconds with 35 queries
