Ttb to solid axle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 16th, 2013, 03:35 AM   #1
beaterk5
beaterk5's Avatar
Send a message via MSN to beaterk5
Default Ttb to solid axle
I'm not very into fords but I have a 92 f150 with a 6" rough country. I also have a complete 78-9 150 front hp44. Now as for installing this do people usually relocate the radius arm bracket or install shorter aftermarket ones?
beaterk5 is offline   Reply With Quote
Old July 16th, 2013, 06:04 AM   #2
curbdog17
Mini Van
curbdog17's Avatar
yes
Old July 26th, 2013, 05:55 PM   #3
ATOMIC_BADBOY
Shake n Bake
ATOMIC_BADBOY's Avatar
I think full size bronco .com has a lot of info on that swap. I was thinking of doing it myself
ATOMIC_BADBOY is offline   Reply With Quote
Old August 1st, 2013, 03:19 AM   #4
bigblockford79
Big Block Ranger
bigblockford79's Avatar
If it were mine I would definitely relocate the bracket, the factory arms were already a tad short to be used with a 6" lift and the TTB. If you have or can find the radius arms that go with the D44 then use those.
Page generated in 0.18247 seconds with 35 queries
