87 YJ Jeep Project. 90% done. New 33" Tires. Lifted. $2300 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 15th, 2013, 08:02 PM   #1
catalyst
catalyst's Avatar
Default 87 YJ Jeep Project. 90% done. New 33" Tires. Lifted. $2300
$2300 Cash or $3000-ish Trade.
I have a 1yr old and a 2yr old, and they eat up ALL of my free time, so I need to part with this project. Its nearly done, and will make a damn fine jeep for someone with some rather minimal work.
New 33" Wild Country AT Tires with chrome rims. Comes with a 33" BFG KM1 as afull-size spare (nearly full tread), but it will need to be mounted to an included steel rim.
133k Miles
6" Rough Country Suspension Lift
4.2 258 v-6 Motor with carb
4.10 dana 30/35 axles
new sway bar links for the lift
stainless brake lines
New Prothane bushings on the majority of the suspension/front end components. Also has a Prothane pass side motor mount that still needs to get installed.
new trans skid plate / mounts
The body is all solid. Floors are solid.
Has a hardtop that i replaced all the seals and glass on (talk about a PITA!).
Doors were entirely rebuilt with new roller handles, and lock cylinders (with keys!)
brand new front windshield that was professionally installed - and the whole frame was sandblaster, rustproofed and bedlinered.
The whole jeep is bed linered on the inside and outside. The outside is gray tinted bedliner - inside is black.
new headlights/ tail lights lights
Aftermarket radio/speakers
Roof Rack
2 sets of Off road lights
new brakes / rotors / drums
Spare Calipers / Rotors / shoes
New Coil Pack
New Distributor
New Plugs
New Engine / Trans Mount
most of the brake lines are new
Posi Lok cable driven 4wd
new battery
Extra Mirrors (in case you want to run without the doors)
Floors and fenders are all solid with no rot. Coated in 2 tone bedliner - gray on black.
It has a relatively recent tune up and will come with a set of new plugs, as well.
Also comes with a back seat, but you'll need to remount it if you want to use it. I never needed it, so I removed the mounts.
There's rot on the rear of the frame in the typical YJ spots by the rear leaf mounts. That will need to be fixed before you take it off roading.
It will need the windshield wipers hooked up to a switch - I have a CJ switch, but never got around to tapping into the column wires for it.
I also have a spare 33" BFG AT tire for it and 15" rim, but it needs to be mounted.
The guy i bought it off of also had a crazy shackle lift on it, but it had plenty of suspension lift, so i cut the front shackles and dropped it some, but you'll need to do the same to the rear. Its basically cutting the steel and making an "H" bracket out of it. I just don't have time for it, and need something I can take up to my hunt camp and enjoy.
I took it up to the gas station and filled up the tank and it was making a rubbing sound - I think a caliper is hung up, or it might be as simple as the heatshield rubbing. Either way, its an issue. if its a stuck caliper, worry not - as i am also including a spare set of stock calipers.
It also isn't shifting properly - it keeps getting stuck in gear and is hard to go in gear. I drove this home from Taylor a year and a half ago, and it shifted fine - and I replaced the trans skid plate and trans mounts and engine mount. If I pump the clutch, it'll generally shift, so it could my a clutch master cylinder issue (but I just replaced it!). Honestly, I'm guessing something with the alignment is off, since it was previously shifting fine. Either way, the ba-10 peugeot trans is horrible, and if you're going to do this right, it should come out and be replaced with an AX15 or better (I was going to toss an AX15 in it).
It will SELF DRIVE on to a flat bed, but I certainly wouldn't drive it home like this. Then again, you might have bigger balls than I do!
I would be open to a trade for a 4x4 utility quad, or a couple of sport quads or either plus cash. or make an offer.
catalyst is offline   Reply With Quote
Old July 16th, 2013, 12:41 PM   #2
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
You never said what engine is in it and what year axles have been swapped in.
Old July 16th, 2013, 01:29 PM   #3
catalyst
catalyst's Avatar
Sorry. AMC 4.2 engine. Manual trans. No power steering. carb'd.
4.10 Jeep Dana 30/35 axles (not 4.11's!). They were off a 90-something jeep.
I got them because I wanted something that mated better with my 33"s, since my YJ came stock with i believe 3.55's. They came from the jeep guy out in memphis, mi. They were in great shape. I got the new trans skid plate from the same guy.
Old July 16th, 2013, 09:13 PM   #4
Hooperdog
OllllO
Hooperdog's Avatar
what carb is on it? Will the ax15bolt right in?
Hooperdog is offline   Reply With Quote
Old July 16th, 2013, 09:47 PM   #5
catalyst
catalyst's Avatar
it is the factory carb, and you'd need to research the ax-15 conversion and what is involved, but it might not even *need* to be done, yet, because like I said - the trans was fine when I drove it home. I would take a look at it before you swap it if you just plan to use it for a daily driver the BA-10 might be fine for you. If you're going to use it as a toy, then you'll probably want to move to an AX-15. I've never done it before, but this is what I was looking into when I *thought* I had the time to finish it.
http://www.jeepforum.com/forum/f12/w...0-ax15-572434/
I hope that helps?
Old July 17th, 2013, 05:40 AM   #6
Hooperdog
OllllO
Hooperdog's Avatar
How's it run with that carb? I know there were some vaccume issues with that set up.
Old July 17th, 2013, 05:45 AM   #7
catalyst
catalyst's Avatar
It runs real good, but it could probably use a carb tune from someone who is better at it than I am. There weren't really a lot of issues with this carb unless you put it on some really extreme angles from what I read.
Oh, the 4wd is posi lok so the vacuum system has that load taken off it too.
If you have any more general questions feel free to pm me. I don't want to clutter the thread with general questions. Or stop by and take a look at it if you're serious about buying it
Old July 18th, 2013, 02:49 PM   #8
catalyst
catalyst's Avatar
bump
Old July 19th, 2013, 10:44 AM   #9
catalyst
catalyst's Avatar
bump
Old July 22nd, 2013, 07:12 AM   #10
catalyst
catalyst's Avatar
bump
Old July 25th, 2013, 10:38 AM   #11
catalyst
catalyst's Avatar
bump. lots of interest. still looking for $ or the right trade.
Old July 27th, 2013, 07:21 PM   #12
mikey1967
mikey1967's Avatar
Send a message via MSN to mikey1967
still have? and where in roseville?
mikey1967 is offline   Reply With Quote
Old August 2nd, 2013, 08:38 AM   #13
catalyst
catalyst's Avatar
sorry, it is currently pending trade for 2 quads.
Old August 6th, 2013, 09:32 PM   #14
catalyst
catalyst's Avatar
Bump. Lots of offers but nothing I really need, yet.
Old August 12th, 2013, 09:42 AM   #15
BeardedXJ
A Cherokee?
BeardedXJ is offline   Reply With Quote
Old September 5th, 2013, 09:59 AM   #16
catalyst
catalyst's Avatar
Buyer was a no-show. Available once again.
Bump
Old September 5th, 2013, 08:51 PM   #17
bjkttr
bjkttr's Avatar
Can you post some Pics of frame?
bjkttr is offline   Reply With Quote
Old September 9th, 2013, 10:13 AM   #18
catalyst
catalyst's Avatar
Sure thing - i'll try and get some pics posted of it later today. Its a typical rot spot, and its a relatively straight forward repair.
please PM me as I don't always check on this thread.
Thanks.
Old September 9th, 2013, 11:37 AM   #19
cookiemonster
cookiemonster's Avatar
Motorcycle?
cookiemonster is offline   Reply With Quote
Old September 10th, 2013, 06:08 PM   #20
catalyst
catalyst's Avatar
What kind of bike?
As requested - the pics of the rear. These are fairly typical spots on a YJ, and a member on here and jeep forum out of clinton twp actually sells the weld in replacement sections. rest of the frame is nice and solid.
pass side. looking in.
pass side looking in from rear
driver side looking in from rear
Page generated in 0.34724 seconds with 83 queries
