Clean, double duty 94 Grand Cherokee - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 14th, 2013, 02:31 PM   #1
nobarrierz
Default Clean, double duty 94 Grand Cherokee
UPDATES: I put on a set of smaller, street friendly tires on stock wheels. Also aligned it. Now drives straight down the road, no hints of wobble or bump steer. Can work out which set of tires, or both, go with during sale. Also now considering trade offers. Prefer stock, lower mile Jeeps. Maybe something fun to drive.
Just gonna copy my craigslist ad to simplify this for me:
1994 JEEP GRAND CHEROKEE
206K MILES
5.2L V8, AUTOMATIC, Selectable 4wd (not AWD like most V8 Grand Cherokees, has 2HI-4HI-N-4L)
NO RUST! EVEN THE FLOOR BOARDS AND ROCKER PANELS ARE SOLID! NOT A VERY COMMON THING TO FIND IN INDIANA ON THESE GRAND CHEROKEES!
SUSPENSION AND STEERING
5" LIFT
FULL SET OF ADJUSTABLE CONTROL ARMS WITH RE-BUILDABLE FLEX JOINTS (UPPER AND LOWER, FRONT AND REAR)
IRON ROCK OFFROAD DOUBLE SHEAR, ADJUSTABLE, FRONT TRACK BAR AND BRACKET
REAR TRACK BAR RELOCATION BRACKET WELDED ON TO AXLE HOUSING, NOT JUST BOLTED
RUGGED RIDGE CROSSOVER STEERING (NOT CURRENTLY INSTALLED BUT INCLUDED)
REPLACED ALL OF THE WEAK TIE ROD GREASE BOOTS THAT CAME WITH THIS KIT WITH PROTHANE POLYURETHANE BOOTS
ALL NEW SHOCKS
BAR PIN ELIMINATOR STYLE FRONT LOWER SHOCK MOUNTS
BRAKES
EXTENDED STAINLESS STEEL BRAIDED BRAKE LINES, FRONT AND REAR.
NEWER FRONT PADS AND ROTORS
ABS SYSTEM BYPASSED AND REMOVED (ABS LIGHT ON DASH IS ON BECAUSE OF THIS)
UPGRADED TO THE LATER MODEL ZJ BOOSTER/MASTER CYLINDER/RESERVOIR. MASTER CYLINDER AND RESERVOIR ARE NEW
NEW STEEL LINE FROM MASTER CYLINDER ALL THE WAY BACK TO THE REAR AXLE
TRANSFER CASE
SWAPPED IN NP231 FOR SELECTABLE 4WD INSTEAD OF AWD. MORE RELIABLE/STRONGER TRANSFER CASE. ALSO MUCH BETTER AFTERMARKET SUPPORT FOR THE 231 TCASE
RUGGED RIDGE SLIP YOKE ELIMINATOR
TRANSFERCASE HAS BEEN CLOCKED UP 10 DEGREES FOR MORE GROUND CLEARANCE AND BETTER FRONT DRIVESHAFT TO CROSSMEMBER CLEARANCE
ADJUSTABLE DIRECT TCASE SHIFTER LINKAGE TO ELIMINATE ISSUES CAUSED BY THE COMPLEX FACTORY SETUP
AXLES
3.73 GEARING
DANA 30 FRONT AXLE:
AUSSIE LOCKER
SOLID AXLE DIFFERENTIAL COVER
U JOINT AXLE SHAFTS INSTALLED TO REPLACE THE WEAKER CV STYLE AXLES
DANA 35 REAR AXLE
OTHER
CURRENTLY HAS 32" SUPER SWAMPER TSL TIRES. THEY ARE UN-EVENLY WORN AND CUT UP A BIT FROM USE ON ROCKS/ETC. DO OK ON ROAD, BUT ARE NOT THE SMOOTHEST RIDE
PROTHANE SOLID POLYURETHANE MOTOR MOUNTS
FUEL TANK SKID PLATE
ALUMINUM RADIATOR GUARD UP FRONT
INCLUDED BUT NOT CURRENTLY INSTALLED ARE A STEERING/RADIATOR SKID PLATE AND TRANSFER CASE SKID PLATE
LARGER, SECONDARY TRANSMISSION OIL COOLER TO AID OEM COOLER
BRAND NEW BATTERY
TRIMMED FRONT BUMPER STEEL SUPPORT FOR BETTER TIRE CLEARANCE AND OBSTACLE APPROACH CLEARANCE. AS A RESULT, AIR BAG SENSORS HAD TO BE REMOVED. AIR BAG LIGHT IS ON BECAUSE OF THIS AND AIR BAGS WILL NOT DEPLOY.
EVAP CANISTER RELOCATED FROM BOTTOM OF BUMPER SUPPORT TO UNDERHOOD LOCATION
AIR CONDITIONING WORKS!!!
EXTERIOR IS IN VERY GOOD CONDITION. NO RUST. RIGHT FENDER IS DENTED. HAS A FEW SCUFFS/SURFACE SCRAPES.
THE "BAD"
INTERIOR IS A LITTLE DIRTY, BUT NOT FILTHY. SEATS ARE IN GOOD SHAPE. HEADLINER IS SAGGING AND HAS A TEAR ABOVE RIGHT REAR SEAT.
NO RADIO. IT DID NOT HAVE ONE WHEN I BOUGHT IT AND I NEVER GOT AROUND TO INSTALLING ONE.
NO MUFFLER. CURRENTLY JUST HAS AN EXHAUST TURN DOWN AFTER THE CATALYTIC CONVERTER.
INCLUDED WITH SALE OF THIS JEEP WILL BE ALL THE SPARE ZJ PARTS I HAVE. INCLUDED ARE A SPARE 5.2L ENGINE WITH WIRE HARNESS AND PCM. ALMOST NEW RADIATOR WITH SHROUD AND OEM TRANS COOLER. STEERING GEAR BOX. FRONT AND REAR DOOR GLASS, REAR DOOR 1/4 WINDOWS. 2 SETS OF HEADLIGHT HOUSINGS. A SET OF FRONT TURN SIGNAL HOUSINGS AND FRONT CORNER LIGHT HOUSINGS. FRONT STEERING/RADIATOR SKID PLATE. 2 TRANSFER CASE SKID PLATES. SPARE LOWER RADIATOR CROSSMEMBER. AND MORE MISC PARTS.
I BOUGHT THIS JEEP TO REPLACE MY TRAIL ONLY GRAND CHEROKEE. MY PLANS WERE TO PUT ALL THE AFTERMARKET PARTS ON IT THAT WERE ON THE OTHER ONE SO I COULD HAVE ONE THAT I COULD DRIVE EVERY DAY AND STILL BE AN EXTREMELY CAPABLE WHEELER. HOWEVER, SINCE SELLING MY LAST WRANGLER I HAVE ALWAYS WANTED ANOTHER. SO I DECIDED THAT BEFORE I START WHEELING THIS ONE AND BANG IT UP, ILL SELL IT AND START SAVING FOR ANOTHER TJ WRANGLER.
WILLING TO CONSIDER TRADE OFFERS. PRIMARILY LOOKING FOR STOCK, LOWER MILE JEEPS. MAYBE SOMETHING FUN TO DRIVE
$2400 CASH
nobarrierz is offline   Reply With Quote
Old July 14th, 2013, 03:40 PM   #2
98ZJ318
RIP 2-15 12:20 AM
98ZJ318's Avatar
any death wobble? How does it do for a dd? also can you snap some interior pics?
98ZJ318 is offline   Reply With Quote
Old July 14th, 2013, 04:58 PM   #3
nobarrierz
I havent registered it since I bought it, so I havent driven it much on road, just occasionally near my house. I have gone 65 down some rougher roads, never had any death wobble, but it does bump steer sometimes and the tires are pretty unevenly worn so they cause a little vibration at certain speeds. Could use an alignment too, will need one anyway once the crossover steering is installed. With a good set of tires it will be a great driver.
Im planning on getting interior shots after work tomorrow. Wont be able to get to it today.
Also, I forgot to mention in the ad, I have a clean and clear title for it. Just never spent the money to register it since I didnt have a good set of tires to use on the street since I built it.
Old July 15th, 2013, 06:36 PM   #4
nobarrierz
Interior pics added. Also took one of the cluster with it running and during bulb check for proof of CEL bulb working, but no codes tripping it. Took it for another drive today. No death wobble. At higher speeds, 65ish, it started to shake the wheel a bit, but im certain thats tire related. They are pretty rough, and not balanced. Anything below that and it drove fine other than a little bit of drift and the steering wheel off center. AC still blowing cold, even in the 90 degree weather we had today!
Old July 19th, 2013, 06:40 PM   #5
nobarrierz
Weekend bump! Make offers!
Old July 27th, 2013, 09:37 AM   #6
nobarrierz
updated first post, bump
Old August 5th, 2013, 08:12 PM   #7
nobarrierz
Now considering trades for stock, lower mile Jeeps. Maybe something fun to drive?
Old August 8th, 2013, 09:52 PM   #8
nobarrierz
Trades, offers? Bump
Old August 12th, 2013, 05:55 PM   #9
nobarrierz
Price lowered to $2400
Old August 18th, 2013, 09:05 PM   #10
nobarrierz
bump
Page generated in 0.45376 seconds with 53 queries
