Axle won't disengage - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 10th, 2013, 10:23 PM   #1
GetItOffroadGMC
GetItOffroadGMC's Avatar
Default Axle won't disengage
98 K2500 w/push button shift
Previous owner said he replaced the front acuator. Haven't dug far enough to see.
Anyhow, I test drove the truck for an hour on varying roads. Everything was fine. Drove it 30 or so miles home, everything is fine. I leave my house, and make a sharp turn.
After that, I picked up a vibration and a slight CV click, but axle isn't binding while turning sharp on pavement. I crawled under the truck tonight, and had my wife roll forward. It is turning the driveshaft, so that tells me that is the cause of my vibration (front shaft joints are dry)
My question is, what would cause the front axle to stay engaged? If I shift into 4wd, everything functions normally. Locks in, and stays locked under a load.
GetItOffroadGMC is offline   Reply With Quote
Old July 11th, 2013, 07:41 PM   #2
GetItOffroadGMC
Anyone??
Old July 11th, 2013, 08:09 PM   #3
Ebs
The front shaft is suppose to spin even in 2wd, no? Jack up the front wheels and see if the shaft spins freely by hand.
Old July 11th, 2013, 10:05 PM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
the shift fork has a spring to push it back to a neutral position. it may be stuck or broken. if you pop out the actuator you should be able to shift it by hand
Yetti
Old July 11th, 2013, 10:10 PM   #5
Yetti
Yetti's Avatar
Yetti
Old July 12th, 2013, 09:43 AM   #6
GetItOffroadGMC
Thank you guys! I will be tearing into it this afternoon to investigate.
Old July 12th, 2013, 10:57 AM   #7
GetItOffroadGMC
The CVs spin while in two wheel, but the drive shaft shouldn't spin in 2wd.
Old July 12th, 2013, 11:42 AM   #8
GetItOffroadGMC
Ok I've done some investigating.
When I pull the acuator, I can put a screw driver handle in there, and move the shift fork freely.
Drove it with the acuator pulled from the truck, and it is unlocked.
Put the acuator back in, left it unplugged, drove it, and it is still unlocked.
Plugged in the actuator, and its back to being locked in.
I pulled the actuator back out. As soon as I plug it into the wiring (while not installed) the plunger comes out.
Any ideas?
Old July 12th, 2013, 12:34 PM   #9
GREASYHANDS
GREASYHANDS's Avatar
Its possible that the switch on top of the transfer case is stuck in the engaged position, this would turn on the front actuator
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old July 12th, 2013, 12:58 PM   #10
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
What type of actuator is it? a thermal one will have a wire attached to it and an electric one will have a plug in.
Old July 12th, 2013, 02:33 PM   #11
firestorm
If it has Autotrac, the front shaft will always turn and I think they started introducing Autotrac around that year.
Autotrac trucks have an Auto4WD option on the push button panel, in addition to 2WD, 4WD and 4Lo.
firestorm is offline   Reply With Quote
Old July 12th, 2013, 02:54 PM   #12
wave_crusher
I'll Direc your TV
nvm....I thought about it and answered my own question; if it is push buttom 4x4 then it has an electric actuator lol
I would check the wires, somewhere the actuator is getting constant power or not getting the reverse power to disengage it. Your shift button could also be broken. It sounds like the actuator is not getting the signal to disengage, there is two sides; one power wire engages it and the second engages it; I believe it is a 3 wire harness because of that.
Old July 12th, 2013, 10:15 PM   #13
GetItOffroadGMC
Not an autotrac.
The actuator has two wires coming out of it, that has a plug on the end. (Pretty sure two wires, I will recheck tomorrow) It is a plunger type device.
I'm leaning towards it getting constant power from somewhere.
I will be tracing wires more thoroughly tomorrow to see of I can track the problem down. Casey said it was probably something wiring too, so I guess the hunt begins.
Old July 12th, 2013, 10:21 PM   #14
GetItOffroadGMC
I will begin there tomorrow as that sounds very much like what's happening
Thanks again everyone. I will update again tomorrow.
Page generated in 0.25632 seconds with 65 queries
