Michigan and water in basements? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 8th, 2013, 08:26 PM   #21
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
A water or battery powered back up pump is also a great idea. Mandatory in my opinion if you have a finished basement.
Old July 8th, 2013, 08:35 PM   #22
BlooMule
Old School
BlooMule's Avatar
My mother's house (was my grandparent's house) has a dry basement. My grandfather dug it out by hand, and knowing how he overdid everything, probably put a 3 foot diameter drain tile in
-rw-rw-rw
Old July 9th, 2013, 08:06 AM   #23
Blue XJ
The Green Machine
Blue XJ's Avatar
Send a message via AIM to Blue XJ
Originally Posted by MonkeyBiz View Post
There are solutions for that. My friend, that I referenced earlier, has a battery alert system on it that once water in the pit reaches a certain level, it goes into audio alarm, and then starts calling up to 5 preset phone numbers. Theory is that if you aren't home, you can either get your ass there, or have somebody scoot over and hook up a small generator.
Or get a backup pump, either battery powered or water powered. My water powered one has saved my basement from getting wet a couple times. On that note, do not buy the stainless steel premium sump pump Lowe's sells, I'm on my third one in just over a year.
Blue XJ is offline   Reply With Quote
Old July 9th, 2013, 08:08 AM   #24
Blue XJ
The Green Machine
Blue XJ's Avatar
x2. The one you put in for me works great, when it's needed.
Old July 9th, 2013, 08:20 AM   #25
Rob the plumber
Great to hear. Zoeller or Hytic are the 2 pumps I'd recommend. I'd don't get to excited over any of the pumps the Depot or Lowes sells. Tsurumi make a top notch pump too, but they are generally used in heavy duty/industrial applications.
Old July 9th, 2013, 10:21 AM   #26
firestorm
I understand that and absolutely would have a backup if a sump pump was essential. I'd just greatly prefer that flooding be an extraordinary event. The flooding this spring is one thing, but I know homeowners that have water infiltration every time there is a heavy rain simply because their house is *in* the water table during those times. It sounds like that may be the situation with your friends house. If the price was right, I'd consider a house with that problem, but otherwise I'd find it to be a unnecessary source of stress.
firestorm is offline   Reply With Quote
Old July 9th, 2013, 10:44 AM   #27
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
I'm still trying to figure out why I have water coming up out of one floor drain, running across the floor, and into the other drain, and if there's an easy fix.
Old July 9th, 2013, 08:15 PM   #28
skife
skife's Avatar
Originally Posted by vr View Post
some are empty, some not. The power is still on at every house I've looked at. All of them have had working sump pumps but the basements are still damp and/or have some standing water. They've all had mold on the walls too so it's probably not just one bad season.
working sump pump with standing water?
bullshit.
Old July 9th, 2013, 08:43 PM   #29
vr
vr's Avatar
bullshit.
true story.
just because the pump works doesn't mean the liquid makes it to the crock.
vr is offline   Reply With Quote
Old July 9th, 2013, 08:48 PM   #30
joe_jeep
welfare wheeler
joe_jeep's Avatar
my moms house leaked bad growing up. one summer, my friend matt and i, dug all the way around the house down to the footer with shovels. it sucked! we had a wrap around cement patio on 3 sides. the right rear corner was a complete screw job, and over 8" thick. most was 4" thick. did it all with 2 sledge hammers. we cleaned and coated the outside walls with tar. wrapped the whole house in thick plastic wrap. re-coated in tar, wrapped in plastic again, then coated that in tar. we dug an 8' deep dry well out in the back yard. filled it with the concrete we broke up from the patio. we backfilled around the house, by hand, with sand and pea gravel. we sloped drain tile around the house, to the low point in the rear, going to the dry well. it was the worst job i have ever done in my life. we did not want to break up the basement floor, there was no sump pump installed.
but the basement is dry to this day!
you can have a dry basement in michigan.
it will be a ton of hard ass work!
or it will cost alot of money!
good luck
Old July 10th, 2013, 12:35 AM   #31
BlooMule
Old School
BlooMule's Avatar
Put a piece of PVC pipe in the drain that the water is coming out of, and run it to the drain that it's going to....
-rw-rw-rw
Old July 10th, 2013, 06:00 AM   #32
kmanxj5011
kmanxj5011's Avatar
I have a damp/wet basement. And I agree with the gutters etc. The side of my house that gets wet is uphill, my roof slopes to that side and the gutter is junk, and the neighbors driveway slopes that way too. I run a dehumidifier year round.
There is about two to three feet of grass between my basement and their driveway. I am going to cement that whole thing and re do my gutters.
kmanxj5011 is offline   Reply With Quote
Old July 10th, 2013, 07:35 AM   #33
Lots of reasons they can be wet, and generally everything is correctable.
Our last house was in an low area, that hard hard clay around 4ft down, then mostly fill sand. When it rained, it seemed all the water from the street came and sat in our yard. The sump pump ran all the time, and the basement flooded during a big ice storm/power outage that brought a lot of rain. (granted, I knew several people that had similar floods that storm, it was a once in a decade thing).
I replaced the old pump with a very good one (also the new pump had a much lower starting/locked rotor current, which helps a lot trying to run them off a small generator!!!), and also a good battery backup pump.
I also found that the previous owners had the sump water just dumping a few feet outside, so with the sand, it just went back into the ground and seeped into the sump again.
I dug all around the house 2 ft down, ran fabric-gravel-new drain tile with holes drilled all over (expect the bottom inch, so water didn't run out the bottom), >more gravel > more fabric. The gutters also dumped into this. The low points of the drain tile ran into a run 100ft from the house to the lowest point in the hard, into a dry well I put there. In wet times, we'd have a 30ft pond at the dry well, but the house always stayed dry.
That house was a pretty extreme case. Like, in the spring when I first got the house, the sump pump would run every 90 seconds at time, thats how fast water was coming into the lower drain tiles.
A battery back up with an alarm and a seperate output pipe also saves your ass if your main pump fails, the pipe is frozen shut, etc.
Our new house, heh, I live on top of a sandy steep hill. No sump, no issues. There was a few times that two cornerse seeped, that was from improper downspouts dumping water against the foundation. They are run out away from the house now, no issues. Mostly, our gutters go through smooth 4 ft PVC underground to the edges of the hill.
Just have to look at all of those things. Is it rain water, or groundwater thats making it damp, or both.
Rain water is generally just fixing the gutters and ground slope by the house. I have done what Joe Jeep talked about with tar, when I did landscape 20+ years ago. We did some landscapes that had sunken entrances to daylight basements that just collected water. Backhoe + tar on the fountation, and good drains in the patio by the door that led into correctly working drain tiles and sump pump fixed that.
Groundwater, you just need to have a correctly functioning tile and sump system, and make sure the sump water is getting out away from the house.
Old July 10th, 2013, 02:35 PM   #34
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
The house I bought has a sump pit. The washer and furnace dump into it. The PO (an old man, original owner) disconnected it from the septic line, and ran it outside. I can only assume this was done to not fill the septic tank. This is resulting in a wet wall where it dumps out on the ground.
My questions, is people with a sump, where do you dump in into? Your septic, the ground, or a separate tank/buried barrel?
Old July 10th, 2013, 03:15 PM   #35
Rob the plumber
It sounds like one floor drain is on the storm system, and the other on the sanitary. One system is likely backing up.
Old July 10th, 2013, 03:19 PM   #36
Rob the plumber
Its not code to dump any fixture into a sump pit. The lines typically discharge into a storm sewer, tie into the sanitary, dump out in the grass, or into a French drain.
Old July 10th, 2013, 03:22 PM   #37
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
No idea... It was that way when the home was inspected by the health department when I bought it. He said that a lot of older people do it to keep from unnecessarily adding discharge to their septic tank.
Old July 10th, 2013, 05:36 PM   #38
Rob the plumber
Health department? I've never heard of them inspecting residential homes. Maybe building department? Either way, it's not code, but inspectors let things slide.
Old July 10th, 2013, 05:41 PM   #39
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
In the house I grew up in, my Dad and I ran a line from the sump out to the woods on one side of the house, and a line from the clothes washer to the woods on the other side to keep from filling the septic up.
Old July 10th, 2013, 07:05 PM   #40
Flexin' XJ
Flexin' XJ's Avatar
Our house has a B-Dry system all around the interior perimeter of the basement. They dug a trench all around about 8-10" wide, laid tile, filled it and covered with a crappy filler cement.
Only time we had water was when the power went out during a storm and the sump pump didn't work. It basically catches water that gets in and drains it to the sump crock.
Flexin' XJ is offline   Reply With Quote
Page generated in 0.55698 seconds with 83 queries
