ZJ: Misfire/ hesitation/ stumble - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 8th, 2013, 08:42 AM   #1
beaterk5
beaterk5's Avatar
Send a message via MSN to beaterk5
Default Misfire/ hesitation/ stumble
96 grand with the 5.2l I'm assuming it was severely neglected. I installed a new oil pump and pickup tube it fixed my knock from no oil pressure. But it throws random misfire code, idles really rough, an stumbles bucks backfires then try's to stall. Cap rotor plugs and wires look fine. Are there any common problems with these?
beaterk5 is offline   Reply With Quote
Old July 8th, 2013, 10:03 AM   #2
ajmorell
ajmorell's Avatar
FWIW when my upstream o2 sensor shit the bed it started acting like that, this was on a 98 4.0
Old July 9th, 2013, 10:32 PM   #3
beaterk5
beaterk5's Avatar
Looked into it more, fuel pressure is 45psi, and up stream o2 is toggleing as it should.
Old July 10th, 2013, 11:07 AM   #4
firehawk
Live Action!
firehawk's Avatar
Leakdown and compression test, do it.
Old July 15th, 2013, 03:58 AM   #5
beaterk5
beaterk5's Avatar
Had low comp cyl 2 but not to low. Leak down was through the crank case. Changed the plugs went one range hotter and it went away. After that threw it a cap and rotor and it ran like new.
Page generated in 0.12729 seconds with 38 queries
