Double ended steering ram - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 7th, 2013, 08:31 PM   #1
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Default Double ended steering ram
I think I'm going double ended, what kind and where from should I buy?
Old July 7th, 2013, 08:38 PM   #2
koochman450r
koochman450r's Avatar
I know many people including myself that use these. Great for the money. http://www.surpluscenter.com/sort.as...c&keyword=HCP1
you won this battle.
Old July 7th, 2013, 08:46 PM   #3
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Mine works great!
H.o.r.e
Old July 7th, 2013, 09:04 PM   #4
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Thinking this one looks about right. What do you use for stops and connectors to the tierods.
http://www.surpluscenter.com/item.as...name=hydraulic
Old July 7th, 2013, 09:08 PM   #5
bigbchevy
missmrgreenagain
bigbchevy's Avatar
I screwed Hiems in the end of my ram and made tie rods out of .250 wall
H.o.r.e
Old July 7th, 2013, 09:15 PM   #6
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
How did you attach your heims to your tie rods?
Pics?
Old July 7th, 2013, 09:21 PM   #7
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Clevis looks like what I need.
Old July 7th, 2013, 09:29 PM   #8
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Ill try to take some
H.o.r.e
Old July 7th, 2013, 10:01 PM   #9
lgottler
lgottler's Avatar
I used the surplus center ram too, made my own clevis...
lgottler is offline   Reply With Quote
Old July 8th, 2013, 03:48 PM   #10
bluminade
Bluminade Has Arrived
bluminade's Avatar
i made the clevis on the tie rod and put the hiem in the ram. it was cheeper and not as many bolts and nuts to loosen up.
bluminade is offline   Reply With Quote
Old July 8th, 2013, 04:02 PM   #11
I wouldn't do high steer with double ended on your stock knuckles.....I've seen you drive .
I was planning on De when I replace my knuckles. Not before.
Old July 8th, 2013, 04:44 PM   #12
revdog
What happens with double ended with high steer on stock knuckles? Just curious.
Sent from my DROID RAZR using Tapatalk 2
revdog is offline   Reply With Quote
Old July 8th, 2013, 04:54 PM   #13
The stock kingpin knuckles are weak in the caliper area. With how we wheel, and the stress of the high steer on a double ended ram is a bad combo. Creating a double sheer using the hi steer and stock tie rod hole will probably help a great deal in releaving said stress.
Old July 8th, 2013, 04:55 PM   #14
bigbchevy
missmrgreenagain
bigbchevy's Avatar
When you doing this?
H.o.r.e
Old July 8th, 2013, 05:39 PM   #15
revdog
I'm fighting a toe out issue on a rig I bought. I see nothing bent.
Old July 8th, 2013, 06:53 PM   #16
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Lol, Iearned from you!
This is what I was thinking. Also allows me to truss the front for the ram mountain t
Not till September ish.
Old July 8th, 2013, 06:53 PM   #17
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I like that idea, thanks.
Old July 8th, 2013, 06:57 PM   #18
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Hrmm I like where your headed Kyle
Old July 8th, 2013, 07:14 PM   #19
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
https://www.rydelfab.com/index.php?r...&product_id=52
You can do this to your knuckles....i cut out my own pieces and did mine.....don't know if it actually helps but it seems like it would.
I had planned to use a surplus center double end ram but i can't run high steer do to frame interference and i didn't like any mounting solutions i could come up with using stock height so i went single ended
974x4Taco is online now   Reply With Quote
Page generated in 0.48635 seconds with 81 queries
