Which manual tranny/case to use for a 302V8 swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 6th, 2013, 12:36 PM   #1
jeepers48
jeepers48's Avatar
Post Which manual tranny/case to use for a 302V8 swap
Im picking up a 1984 5.0(EFI) mustang Sunday 7/7/13.
It currently has a 5 spd tranny behind it. Im going to part out the Mustang and kicking the idea around to swap the motor into my Willies Wagon. I'd rather drop in a 4 or 5 spd trans. What's my best scenario/option?
If I cant find something, then I might opt to putting a C4 trans behind it but will end up looking for the auto mod to replace the manual mod that it has now.
Any info would be a big help, thx.
Anyone have a 4 or 5 spd w/case?
jeepers48 is offline   Reply With Quote
Old July 13th, 2013, 08:55 AM   #2
insaneoffroader
insaneoffroader's Avatar
I have this
Np435 - Great Lakes 4x4. The largest offroad forum in the Midwest
If parts ain't flyin' you ain't tryin'
insaneoffroader is offline   Reply With Quote
Old July 13th, 2013, 11:59 AM   #3
Ebs
ZF5 if its going to see street/highway duty. Four speed if its a trail truck. '84 is pretty unimpressive if its a factory engine (which probably isn't if its been swapped to EFI), find an Explorer/Mountaineer 5.0L.
Old July 13th, 2013, 05:10 PM   #4
jeepers48
jeepers48's Avatar
Well Ebs, today I eat "Crow" I have the Mustang on Craigs list to part out the rest of the car, a guy stopped over to buy the wheels, seeing the motor on the engine stand, he told me "no way the motor is from a 1984 Mustang. Must be 87 on up. He told me it looks like the upper intake came off a later ford explorer, but definitely has GT40 heads on the motor.(I popped the valve covers) I pulled the valve covers off the other day, for inspection to reveal it does have Ford Factory roller rockers.
I haven't, so far, been able to locate a ZF5spd. Other tranny swaps ive read about on the Novak site were a ford T-18, jeepT176, jeep AX15.
Yhe T-18 and AX15 would endup drivers drop cases and if I found a T-176, would be a pass drop case. im leaning towards a T-176. I had one once before and it held up fine behind a amc401. I used it rock crawling and briefly(2 days)sand drags.
Old July 20th, 2013, 07:53 PM   #5
Hoofinit
Hoofinit's Avatar
http://car-part.com/cgi-bin/search.cgi
If this the link doesn't work just go to first part of address. A 205 will bolt up with some grinding, this combo measures 42" from block to ujoint. You will need to support rear of tcase as tranny is aluminum.
Hoofinit is offline   Reply With Quote
Old July 21st, 2013, 09:53 AM   #6
Hoofinit
Hoofinit's Avatar
http://classicbroncos.com/forums/sho...light=zf+np205
Page generated in 0.24373 seconds with 42 queries
