Stalling issue - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 5th, 2013, 09:34 AM   #1
Whatisfreedumb
Whatisfreedumb's Avatar
Send a message via AIM to Whatisfreedumb
Question Stalling issue
Jeep info:
99' cherokee classic
4.0 I-6 stock 170k (231k on the body)
Replaced wires and plugs about a month ago
Replaced IAC, Tps, temp sensor,
D30 high pinion/8.25
No mods.
Any further info needed just ask.
Ok guys maybe someone can help me out here.
Basically yesterday while I was out, I pulled over to check out a vehicle leaving my jeep run, when I got back in and put it in gear everything seemed normal as we got going my dash "dropped out" meaning it wasn't reading anything and the car stalled out, Started right back up no problem. Continued driving it as we drove it was alright for the most part up until it came to slowing down when it would downshift into first it would hesitate choke and stall. Took it to the shop hooked it to a scan tool it's only shooting a code for the temp sensor as the plug makes a bad connection. There is some corrosion on the firewall ground, I cleaned up the terminals and made sure there was no issues as far as that went. It seems like the jeep wants to idle high (900-1200) when in gear and 300-600 when in neutral) it also smells like gas and seems like the engine could be flooding itself.
Also: last night when testing things I did get the odometer to read "no bus" which meant it wasn't recovering information from the PCM? Yet I got it to start shortly after. It was the first time I got the message and couldn't get it to start right away
Whatisfreedumb is offline   Reply With Quote
Old July 5th, 2013, 11:44 AM   #2
Whatisfreedumb
Today going out to it I'm having an issue starting it unless I give it gas once it's started it's idling extremely low and the alternator is extremely hot...
Old July 5th, 2013, 06:10 PM   #3
Cool parts peddler
Ironman Offroad's Avatar
Alternator is probly going bad, causing excessive AC voltage and the computer cannot deal with AC voltage. Connect a volt meter to the alternator output and check AC voltage.
Old July 6th, 2013, 11:49 AM   #4
Whatisfreedumb
Update: regrounded the engine, installed a new battery and had the alternator tested at the local shop. Test came back "good" cleaned up the terminals and connections on the alternator and hooked it back up played with the harness finally it was running smooth but my idle is still a bit high cleared all my codes and got it to shoot p0505 which is a "idle control system malfunction... Any ideas where this could lead me?
Old July 7th, 2013, 08:59 AM   #5
Whatisfreedumb
Final update, after numerous test and poking around it ended up being the IAC valve located on the throttle body. I made 6 trips to autozone, needless to say I will never go there for parts again.. They gave me 3 faulted parts, 1 previously installed part and the wrong part and refused to return it after I was so fed up and walked to o'rileys got the part. installed it right there plugged it in, cleared the code and started her up. She is running beautifully now:D
Thanks for the input ironrock much appreciated!
Tags
cherokee, jeep, sensor, stalling
Page generated in 0.23570 seconds with 38 queries
