YJ: 4 liter fuel system help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 4th, 2013, 08:13 AM   #1
Westside Willy
Westside Willy's Avatar
Default 4 liter fuel system help
Totalled the XJ on 131 in January. Acquired an 89 YJ with a wheezing 2.5 and decided to swap the XJ drivetrain into the YJ. Donor is 98 XJ 4 liter / Aw4. The swap is coming along and I have acquired the fuel tank from a 95 YJ for the higher pressure pump and bolt in factor. This is when I found out the early 4 liter HO systems use a 2 fuel line pressure and return system. The 98 engine uses the single line and dumps pressure in the tank. All I have found on the early system is the drawing in the factory service manual.
My options are to find a TJ tank or fuel rail from an early 4.0 HO - I think
Questions:
A] Is the early fuel system regulator a mechanical regulator ? Are there any other differences ? Will the 98 PCM work with the 95 set up ?
B] Will a TJ fuel tank bolt into a YJ ?
C] Anyone have the parts I need ?
Thanks in advance for the help.
Westside Willy is offline   Reply With Quote
Old July 6th, 2013, 08:21 AM   #2
Westside Willy
Anyone have pic of a 91-95 4 liter fuel rail ? I think there is a vacuum line on the fuel regulator, does it just plug into the intake manifold ?
Thanks
Old July 16th, 2013, 07:52 PM   #3
yyj87
yyj87's Avatar
Thanks
Vac operated reg on rail, there is a 10" long vac line to intake.
I have an extra.
yyj87 is offline   Reply With Quote
Old July 18th, 2013, 06:21 PM   #4
Mulder
Jeeper
Mulder's Avatar
I have the 92 fuel rail with return if you need it.
$10 + shipping.
Mulder is offline   Reply With Quote
Page generated in 0.20578 seconds with 35 queries
