Ford transmission questions- someone school me! - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 9th, 2013, 05:17 PM   #21
Search car-part.com
Trans are cheap. 02 mustang with v6.
I have a 50% off painless gift cert and painless makes a 4r70w controller.
I guess what is your definition of cheap? Seems you cold get a stock trans, controller installed for probably less the $1000. That seems pretty reasonable to me.
Old July 9th, 2013, 07:44 PM   #22
Predator63
Originally Posted by 86scottsdalek10 View Post
Well as stated before if I'm going to replace the trans I am going to put something in there with overdrive. The c4 isn't an option and the e40d is bulky so that leaves me with the 4r70w.
Predator I believe I responded to your thread but that is the 4wd version which won't work for my application.
I guess I was under the impression that I could get a fairly cheap trans with an overdrive and some sort of controller for it relatively cheap but I suppose not?
10 4. Must have missed that.
Predator63 is offline   Reply With Quote
Old July 16th, 2013, 07:11 PM   #23
86scottsdalek10
86scottsdalek10's Avatar
Did a little research and I'm not too fond of the e40d. Looks like the aod has the same ratios as my c6 except for 4th gear is .675 I believe. With a decent converter it would put me at 65 mph at 2200 rpm on the eway. Otherwise I would have to convert the 4r70w to full manual valve body to avoid the electronics. Anybody confirm this?
86scottsdalek10 is offline   Reply With Quote
Page generated in 0.22873 seconds with 32 queries
