TJ: Transmission Line Leak - Gauge - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 3rd, 2013, 06:15 PM   #1
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
Default Transmission Line Leak - Gauge
2002 TJ 4.0L
About a month ago, I installed a Sunpro Transmission Temperature Gauge in the Jeep. I cut the input line to the transmission, installed a T fitting, and plugged the sender unit into the top of the T. Well after a wheeling trip out to the Dunes last week, I have begun to develop a leak at the T Fitting. It is getting all over the exhaust, causing smoke and a bad smell, and is getting progressively worse.
I pulled the T fitting completely off last night and used teflon tape on all of the threads and reinstalled. As far as all of those threaded spots go, it hasnt leaked from them since. But the actual sender unit itself, has begin to leak. Has anyone else ever experienced this?
As you can see in the attached picture, that is the "exact" spot where it is leaking from. Before it was that spot and the threads, now it is just that spot. I don't think it is possible to fix, but if so, maybe you guys can shed some light on this topic for me.
I think I may just have to pull the sensor and plug up the hole with a fitting, but do they sell close ended fittings to block off that port?
Thank You
Catnip 0_o is offline   Reply With Quote
Old July 5th, 2013, 07:16 PM   #2
Cool parts peddler
Ironman Offroad's Avatar
Put some teflon based pipe dope on the sealing surface of the sender and on the threads on the sender (seals and lubricates). Learned that from the pipe fitters in the family.
Old July 5th, 2013, 09:28 PM   #3
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
It is leaking from between the threaded "nut" and the tubing? I am looking from my phone so it is hard to tell. It is flare isn't it?
Old July 5th, 2013, 09:38 PM   #4
crazymanme2
+1 on flare or a special fitting that sender goes in.Mine had a special fitting that the probe seated in & the outside was pipe thread.
crazymanme2 is offline   Reply With Quote
Old July 6th, 2013, 01:33 PM   #5
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
Yes it is a flare fitting, I will need a special adapter?
Old July 6th, 2013, 01:52 PM   #6
skife
skife's Avatar
probably the flare
also, undo all of what you done and move your temp gauge to the output of the transmission, the input would give you the temperature after everything has been cooled by the cooler.
Old July 7th, 2013, 10:03 PM   #7
sandfox4
napadave
sandfox4's Avatar
does it use a cappilary tube like a manual water temp sender ? it looks like it, if so it is kind of a flare fitting, but you should only have to tighten it up to get it to stop leaking, tear it apart ,clean it up, put sealer on it and torque it tight.
sandfox4 is offline   Reply With Quote
Page generated in 0.24262 seconds with 45 queries
