"Batfly" rotors - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 27th, 2013, 10:53 AM   #21
cerial
Direct Drive FTW
cerial's Avatar
Some crappy pictures I kicked out while on break. My scanner does not work without ink so they were taken with a pos phone.
Basically I am going to take a pipe, weld a flange on the inside with holes to match my bolt circle, then weld another flange on the other end on the outside of the pipe with bolt holes for studs. I will have a ring cut which will serve as the rotor wear area that will bolt to the outside flange. This will let me simply cut out new wear rings instead of replacing the entire rotor when needed.
The caliper mounts to the upper portion of the steering knuckle. It will be around 25" off the ground.
It is progressing just slow due to funds.
I need to get the new stud mount 22.5x8.25(r11) rims first. Once I have the rims I can mock up mount my steering box(on the axle) and linkage to see how much room I have to work with inside the rim. Then I can determine the size of pipe and which caliper will provide the most surface area. Once I know how much wear area I am working with I can start looking at different calipers to see which one will give the largest footprint.
I plan on mounting the "street" 22.5 rims/tires inside the hub. For off road (mostly snow/mud) I will be using 54" xl 's on r20's mounting them outside the hub. Doing this lets me have the larger tire and same turning angles without changing my wheelbase. The downside is that the rotor will be hanging 5" below the axle tube. On the rear I am simply going to install a "rock guard" connected to lower truss. I am still unsure how I am going to protect the front rotors at this point.
The entire point is to mount the caliper as high as possible to whip off derbies giving better breaking/life while making the wear parts easy and cheap to replace. Placing the rotor in open air will also keep the caliper and rotor cooler.
Old August 27th, 2013, 11:27 AM   #22
GREASYHANDS
GREASYHANDS's Avatar
Does it hurt, being so smart ?
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old August 27th, 2013, 08:40 PM   #23
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
As long as the rotors stay dry it doesn't matter how hot you get them they don't warp....I'm willing to bet I've put a car threw its paces more than anyone on here and after three days of testing, one set of tires and one set of pads, the rotors were not warped...
Old August 27th, 2013, 09:11 PM   #24
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
I am willing to bet that you will die of old age before your buggy is done.
Old August 27th, 2013, 10:55 PM   #25
Wramblerguy
Wramblerguy's Avatar
Careful, don't over think it
3rd generation jeeper
Wramblerguy is online now   Reply With Quote
Old August 28th, 2013, 06:16 AM   #26
Mr.Green
I can levitate!
Mr.Green's Avatar
Originally Posted by High Center Hancho View Post
As long as the rotors stay dry it doesn't matter how hot you get them they don't warp.....
Rong again. This may be kinda true with Cop rotors, a low quality or even home made rotor can warp with aggressive braking and getting it too hot.
Old August 28th, 2013, 06:19 AM   #27
Mr.Green
I can levitate!
Mr.Green's Avatar
Originally Posted by cerial View Post
On the rear I am simply. easy and cheap.
My favorite words when I read Cerial's posts.
Old August 28th, 2013, 06:38 AM   #28
Christmas Cookie
GM OEM rotors will not warp no matter how hot you get them
Old August 28th, 2013, 07:53 AM   #29
Mr.Green
I can levitate!
Mr.Green's Avatar
Thats funnay. Not to get too technical with your rong ass, but if you get them too hot, they will melt. What about Cerial OEM?
Old August 28th, 2013, 07:55 AM   #30
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Lol
H.o.r.e
Old August 28th, 2013, 05:59 PM   #31
Christmas Cookie
It is impossible to get them too hot by using them, I'm sure if you used a torch you could melt them, but not by using the brakes on a track for three days straight at a race pace
Old August 28th, 2013, 06:32 PM   #32
cerial
Direct Drive FTW
cerial's Avatar
Most rotors fail due to bad mounting practices. Ie derbies at the hub flange during mounting or over/under torquing in general.
This thread was about the Batfly junk on those type of rotors and it is concluded they simply are not worth the trouble. Thanks for all the help.
Old August 28th, 2013, 07:12 PM   #33
Christmas Cookie
I have them on my dirtbike, the extra bite is worth in if you ask me
Old August 28th, 2013, 07:45 PM   #34
firehawk
Live Action!
firehawk's Avatar
I would like to convert my hydraulic brakes to electric. Any help is welcome.
Old August 28th, 2013, 10:52 PM   #35
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Swap the brakes off a Maybach.
Old August 28th, 2013, 10:57 PM   #36
Wramblerguy
I hear cable operated is the way to go
Old August 29th, 2013, 06:55 AM   #37
Mr.Green
I can levitate!
Mr.Green's Avatar
Oh, the 72 hours of Brandon race? How did you finish? Sounds amazing!!
Page generated in 0.41304 seconds with 75 queries
