Yj 32rh wiring lock up converter.. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 2nd, 2013, 07:52 AM   #1
yj-woody
member
yj-woody's Avatar
Question Yj 32rh wiring lock up converter..
trying to finish up my jeep.. Put a 32rh auto in it. Had the ax15. Need to hook up the torque converter lock up.. But don't want to run a toggle switch. Can you tell me another way to run it? If i do a switch i know the wife will forget to turn it on or off.. LOL OR is a toggle switch the ONLY way to do it???
yj-woody is offline   Reply With Quote
Old July 2nd, 2013, 08:07 PM   #2
yj-woody
member
yj-woody's Avatar
Night bump!
Old July 3rd, 2013, 03:57 AM   #3
yj-woody
member
yj-woody's Avatar
No one know's how to wire it up?? What has everyone done about it?
Old July 3rd, 2013, 08:34 AM   #4
yj-woody
member
yj-woody's Avatar
bump
Old August 1st, 2013, 10:45 PM   #5
cdw32
cdw32's Avatar
There's really no way to do it without having the TJ ECU since the 32RH is a TJ tranny and not a YJ tranny thus there is no hot wire coming from the YJ ECU to the tranny. You will have to run a toggle switch. You could even run that tranny as a non lock up and it would be fine, you just wouldn't have that little bit of overdrive that a lockup tranny provides.
cdw32 is offline   Reply With Quote
Old August 2nd, 2013, 05:24 AM   #6
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Yeah, leaving it unlocked wouldn't be a big deal.
Page generated in 0.21152 seconds with 41 queries
