need some help - LS1 not running right - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 30th, 2013, 07:56 PM   #1
knaffie
knaffie's Avatar
Default need some help - LS1 not running right
I was at the dunes last weekend. It ran fine for first 2 hrs Friday then started sputtering under hard load at any RPM. Thought I was running out of gas so I filled up. Saturday ran fine for first 30 min. then did same thing. Found the problem goes away after it cools for a while. As soon as it gets hot, like over 200, it comes right back. Normally runs at 210 - 220 under hard load, so its there the whole time I'm pushing it. Fuel pressure is 58 psi at the rail never budges. I thought the ecm was maybe getting hot so took hood off. Seem better, but problem is still there. Put on new fuel pump, no help. Speed density tune no maf. No codes. Fuel? Electrical? Help please.
Easy to hear it starting at 0:14 (after the rev limiter, then shift) and at many other spots during the video.
Old June 30th, 2013, 08:05 PM   #2
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Dirty injectors?
Old June 30th, 2013, 08:07 PM   #3
knaffie
knaffie's Avatar
And how would I tell if they are or are not? I put some additive in every tank, Seafoam, Regaine, Lucas, etc.
Old June 30th, 2013, 08:31 PM   #4
chevotass
chevotass's Avatar
fuel lines getting hot?
Old June 30th, 2013, 08:33 PM   #5
knaffie
knaffie's Avatar
Every time I feel the pump and lines, they are not. I was told that the fuel will "boil itself inside the pump if the pump is not submerged. But so many people run the Bosch 044 externally without issues. And its just a stock LS1, its not like I'm moving fuel for 600HP or something.
I don't want to exclude any ideas, but the fuel system has not changed on this car since day #1, and except sucking fuel cell foam into the filter during KOH, it has never had a fuel problem. This problem just appeared after I got it re-tuned. Maybe coincidence, maybe not.
Old June 30th, 2013, 08:47 PM   #6
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
sounds almost like a ignition coil going bad. i had a similar condition with my 06 2500. #4 was going bad it had an intermittent miss. finally it shit the bed and i had a dead cylinder.
Old June 30th, 2013, 08:48 PM   #7
knaffie
knaffie's Avatar
I wish it would just shit out already so I can fix it and move on. I want my horsepower back!
Old June 30th, 2013, 08:51 PM   #8
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
do you have access to a scan tool with live data? if you do hook it up and watch the misfire counter while running. the cylinder with the highest misfire count would be my suspect.
Old June 30th, 2013, 08:53 PM   #9
knaffie
knaffie's Avatar
No. I need to call my tuner and make an appointment for next week. I can put my winter tires from my dmax on and run it on his dyno. Hopefully. Only way to do it that I know of. It only does it when its hot and you run it hard, so its not like I can just drive it around on the road and do it.
Old July 8th, 2013, 11:13 AM   #10
What did you find out?
Old July 8th, 2013, 11:24 AM   #11
knaffie
knaffie's Avatar
Have not been down there yet
Sent from my DROID RAZR using Tapatalk 4 Beta
Old April 3rd, 2014, 06:14 PM   #12
knaffie
knaffie's Avatar
Just stumbled upon this old thread and thought I would update it. It was the plug wires. Brand new MSD wires all cracked in the boots the first time I had it out last year. I put AC Delco wires back on it (that are half the price) and not a problem since. You'll never see me using MSD wires again.
Old April 3rd, 2014, 07:41 PM   #13
firehawk
Live Action!
firehawk's Avatar
This is the second time I read about bad MSD wires in the past week.
I will never run them.
Old April 3rd, 2014, 07:46 PM   #14
frdboy
frdboy's Avatar
http://www.firecore50.com/
Old April 4th, 2014, 11:34 AM   #15
knaffie
knaffie's Avatar
Here's the pics I was looking for.
Sent from my XT1080 using Tapatalk
Page generated in 0.44970 seconds with 69 queries
