Delete - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 29th, 2013, 07:00 PM   #1
Aquaman
Aquaman's Avatar
Default Delete
I need a 2000-2002 Cherokee motor with 170,xxx or lower miles.
Thanks,
Josh
Aquaman is offline   Reply With Quote
Old July 1st, 2013, 12:11 PM   #2
Aquaman
Aquaman's Avatar
bump
Old July 3rd, 2013, 09:33 AM   #3
Aquaman
Aquaman's Avatar
Bump!
Old July 5th, 2013, 11:21 AM   #4
Aquaman
Aquaman's Avatar
Bump!
Old July 5th, 2013, 06:11 PM   #5
revdog
jfoster on here has one out of a 99 grand which is the same as 2000-2001 sport motor. Good price too.
Sent from my DROID RAZR using Tapatalk 2
revdog is offline   Reply With Quote
Old July 6th, 2013, 10:40 AM   #6
Aquaman
Aquaman's Avatar
Ok thanks!
Old July 6th, 2013, 02:35 PM   #7
Gunsworth
Gunsworth's Avatar
Double check compatibilty, everything i read on 00-01 cherokees said wj and tj motors have different accesory setup and mounting. For direct bolt in you need 00-01 from xj only.
Old July 6th, 2013, 03:53 PM   #8
revdog
He might be right. Jfoster can tell you. But for sure double check.
Old July 7th, 2013, 05:21 PM   #9
Aquaman
Aquaman's Avatar
You're right, I could use the block but I would need to find a different head then and do some parts swapping.
Old July 8th, 2013, 09:10 PM   #10
Aquaman
Aquaman's Avatar
Bump
Page generated in 0.36648 seconds with 53 queries
