Gas Tank cleaning - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 29th, 2013, 03:02 PM   #1
pizzaman
pizzaman's Avatar
Default Gas Tank cleaning
I dropped a gas tank on a jeep, to my surprise, no rust but old gas. removed gas and want to clean. Not sure what use thinking maybe Acetone to help eliminate the old gas and then rinsing with water, air drying and putting back.
Any thoughts on this and or experience with acetone? Do mix the acetone with water? Will it eat the finish in the tank??
pizzaman is offline   Reply With Quote
Old June 29th, 2013, 03:12 PM   #2
XJsport95
Haters be my motivators!!
XJsport95's Avatar
There was a thread not to long ago about the same thing. If I remember he used acetone and everything came out fine, but I'm not sure if it was mixed or not.
XJsport95 is offline   Reply With Quote
Old June 29th, 2013, 05:19 PM   #3
firehawk
Live Action!
firehawk's Avatar
You could just use fresh gas and some fuel injector cleaner, whatever is cheapest I guess is what I would use.
firehawk is online now   Reply With Quote
Old June 30th, 2013, 10:22 AM   #4
skife
skife's Avatar
Fuck it, run it.
Old June 30th, 2013, 11:19 AM   #5
robbietap
muriatic acid
robbietap is offline   Reply With Quote
Old July 2nd, 2013, 07:25 AM   #6
pizzaman
pizzaman's Avatar
Muriatic acid eats the finish then you have to line it. I ended up using acetone and flushed multiple times and it came out great.
Thanks.
Old July 2nd, 2013, 12:15 PM   #7
Lynxer
Lynxer's Avatar
I would never reccomend using water to clean any gas tank.
If its rusty, throw in some gravel with that acetone//gas and shake it up!
Many gas tanks saved with some gravel from the driveway!
Lynxer is offline   Reply With Quote
Old July 2nd, 2013, 12:16 PM   #8
capone
capone's Avatar
I cleaned a few gas tanks with a chain and acetone. It worked great.
capone is offline   Reply With Quote
Page generated in 0.29909 seconds with 47 queries
