4.0l - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 27th, 2013, 05:18 PM   #1
2fst4you
2fst4you's Avatar
Default 4.0l
Looking for a 4.0L out of a 02 TJ must run perfect not burn any oil at all and have under 100k miles
Old June 27th, 2013, 05:34 PM   #2
roadtrip
roadtrip's Avatar
Default engine
Dont waste your money on a used one that was a bad year for the 4.0 a lot of them had bad piston problems. on the 02 4.0 there was a block change and there isnt much you can use but that year I got lucky and found a core for my 02 wrangler to rebuild. a used one can cost well over a grand to 1400 with 100000 on it you can do a short block for around 900 and a long block for around 1800
roadtrip is offline   Reply With Quote
Old June 27th, 2013, 06:19 PM   #3
2fst4you
2fst4you's Avatar
Really? I haven't heard of any 4.0s having problems. If its gonna cost that much to rebuild it or buy a used one I will probably just do an engine swap
Old June 27th, 2013, 07:15 PM   #4
Gunsworth
Gunsworth's Avatar
Early 2000s 4.0s are shit, several different problems. Look at jeeps for sale from that era, most everything over 120k has a replaced motor. The good days of the 4.0 were in the 90s, after that everyone thinks they are the same, but far from it
Old June 27th, 2013, 07:54 PM   #5
1 ton tj on 40's
1 ton tj on 40's's Avatar
get one from an xj.
Old June 27th, 2013, 07:57 PM   #6
2fst4you
2fst4you's Avatar
Ok so they improve in 00' or 01'? I know the rings are bad on my 02. I could do that thought they were the same though....
Old June 27th, 2013, 09:15 PM   #7
firehawk
Live Action!
firehawk's Avatar
Rebuild yours then you know what you are getting and you know your accessories will fit with no problems.
Old June 27th, 2013, 09:25 PM   #8
Gunsworth
Gunsworth's Avatar
lol, no, those are the worst 2 years, they changed more after 02 i think, but not sure on those.
Old June 27th, 2013, 09:29 PM   #9
mudrunner456
mudrunner456's Avatar
I rebuilt mine last year. Had 181,000 on it. Having someone else do the work i had 1400 in it. Picked it up, dropped it in and has been running great ever since. I also thought about an engine swap but to do the 5.3 liter and have it done right would have cost way more money and been down alot longer.
mudrunner456 is offline   Reply With Quote
Old June 27th, 2013, 09:29 PM   #10
mudrunner456
By the way mine is an 02
Old June 27th, 2013, 10:06 PM   #11
Gunsworth
Gunsworth's Avatar
wow, when I called around our area last year most places were over 2k for a rebuild. wound up finding a wrecked jeep with a motor that only had 10k on a rebuild. It was getting close to going your route, given the price of the engines I was finding
Old June 27th, 2013, 10:36 PM   #12
1 ton tj on 40's
get an xj motor there easier to find with low miles
Old June 27th, 2013, 11:48 PM   #13
Aquaman
Aquaman's Avatar
I believe the 2001-2004 Grand Cherokee and TJ 4.0 motors are compatible with each other and would be a direct fit if you went that route but if you choose an XJ 4.0 motor you'll have to swap parts over to the TJ motor because the mounts are different.
Aquaman is offline   Reply With Quote
Old June 28th, 2013, 03:58 PM   #14
1 ton tj on 40's
ya but it's not that bad. I put one in my tj.
Old June 28th, 2013, 04:38 PM   #15
2fst4you
2fst4you's Avatar
I'm going to look into having mine rebuilt may throw a 258 crank in it for shits and giggles
Old June 28th, 2013, 04:39 PM   #16
Aquaman
Aquaman's Avatar
True, I was just passing it on in case he didn't know.
Page generated in 0.30258 seconds with 71 queries
