Is My Clutch Bad? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 26th, 2013, 11:55 PM   #1
Modestmar00Xj
Show me the trails!
Modestmar00Xj's Avatar
Send a message via AIM to Modestmar00Xj Send a message via Skype™ to Modestmar00Xj
Default Is My Clutch Bad?
Question jeepers!
I have a 97' TJ and I think my clutch just went out on me today! Its really hard to push in and feels like theres a lot of resistance. I checked the fluid and its full and the cable appears ok, its not broken. Do you think it could be the clutch plate? And how can you tell? Thanks.
Modestmar00Xj is offline   Reply With Quote
Old June 27th, 2013, 12:13 AM   #2
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
Obviously something went bad, but probably not the clutch plate. That would not cause a hard clutch.
Start with the easy things, check the master and slave cylinder and the pedal assembly for something that would cause increased resistance.
I'm not sure where you found a cable to look at, TJ's have hydraulic clutches.
Old June 27th, 2013, 12:22 AM   #3
Modestmar00Xj
Show me the trails!
Ok cool ill check it out! Yeah i was looking at the linkage from the pedal to the little actuator inside the jeep. Im not sure yet but im thinking it might be the slave cylinder. Thanks man!
Old June 27th, 2013, 07:07 AM   #4
mymizzery
mymizzery's Avatar
a few years back my clutch plate exploded. One of the springs embedded in the plate broke loose and was stuck between the clutch plate and pressure plate. would not disengage. it was the night before the woodward cruise I was not happy to say the least.
mymizzery is offline   Reply With Quote
Tags
clutch, shifting, transmission
Page generated in 0.20345 seconds with 35 queries
