WJ transmission slips and wines - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 26th, 2013, 09:17 PM   #1
14muddn
Default WJ transmission slips and wines
My brother said his transmission had been slipping for a week or two and then he said it won't go past 30. I just took it for a short drive and it shifts from first to second fine under regular acceleration and at 25 slips out and the rpms jump. I could hear a pretty distinct whine I'm assuming the transmission oil pump? I haven't checked for codes but there is a check engine light I'll check when I can get ahold of a scanner (mine is old and the screen has slowly died).
This is a 99 4.7 WJ with 145k original transmission as far as I know.
Is it possible the jeep is sensing a low flowing pump and putting it into limp mode?
Someone said there are a couple sensors that are known to go out, could that be giving a similar issue?
Is it just time for a new transmission?
Old July 18th, 2013, 10:44 PM   #2
14muddn
Anyone have some insight?
Old July 18th, 2013, 11:04 PM   #3
af26yrs
af26yrs's Avatar
I have a 42RE in my part out '04 WJ that was completely rebuilt with all new parts about 55,000 miles ago for sale. When I say completely I mean it has all new parts from clutches to sensors. $125 and you come pull it. Xfer case and drive shafts are already out so just have to take tranny out. PM me if you are interested.
As far as your problem, when was the fluid changed last? You might try dropping the pan and changing the fluid and filter.
af26yrs is offline   Reply With Quote
Old July 18th, 2013, 11:32 PM   #4
joe_jeep
welfare wheeler
joe_jeep's Avatar
the v8 was 545rfe wasnt it?
Old July 18th, 2013, 11:57 PM   #5
ajmorell
99 would be a 45rfe
Old July 19th, 2013, 04:54 AM   #6
af26yrs
af26yrs's Avatar
Wasn't sure if it would fit but offered it.
Old July 19th, 2013, 10:21 AM   #7
14muddn
I appreciate the offer if it was a 4.0 WJ I would be all over it I saw your part out thread lol.
I'll probably drop the oil pan this weekend and if there are any signs of hard damage and pick up a scanner. I don't really want to fill the trans back up if it's going to need work done, if I remember right ATF+4 is a little spendy.
Page generated in 0.22609 seconds with 44 queries
