I need help with a fuel injector - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 26th, 2013, 07:49 PM   #1
mymizzery
mymizzery's Avatar
Default I need help with a fuel injector
I am replacing a fuel injector. is there is a trick to getting the injector back into the fuel rail. I have been trying for about an hour, and I destroyed two o-rings.
mymizzery is offline   Reply With Quote
Old June 26th, 2013, 08:05 PM   #2
70inmotion
70inmotion's Avatar
Use a little grease on the o-ring to make it slide back into the fuel rail. Put the o-ring on the injector first.
70inmotion is offline   Reply With Quote
Old June 26th, 2013, 08:18 PM   #3
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
This. 4.0 fuel rails can be a pretty tight fit. It helps to rotate them back and forth while pushing them in too.
Old June 26th, 2013, 08:23 PM   #4
mymizzery
mymizzery's Avatar
i tried both of those things, and nothing worked.
Old June 26th, 2013, 08:53 PM   #5
Rob the plumber
It works. It's just tricky. Put them in the rail first. A little Vaseline works great.
Old June 26th, 2013, 08:54 PM   #6
Rob the plumber
If you can't get it, I'll be in your area tomorrow pretty much all day. I'll help you out.
Old June 27th, 2013, 07:11 AM   #7
mymizzery
mymizzery's Avatar
PM sent.
Page generated in 0.29675 seconds with 44 queries
