TJ: Fixed pinion angle, now shocks hit the spring perch. Ideas? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 26th, 2013, 05:18 PM   #1
Cummins-coal
Cummins-coal's Avatar
Default Fixed pinion angle, now shocks hit the spring perch. Ideas?
I installed new adjustable rear upper control arms to fix my pinion angle, and now my shocks won't install. The shock body is hitting the lower spring perch, not allowing me to reinstall. Any suggestions or remedies to fix this?
Thanks in advanced!
Cummins-coal is offline   Reply With Quote
Old June 26th, 2013, 05:30 PM   #2
yyj87
yyj87's Avatar
Remove and make it better!
Cut them off and burn one on that works.
yyj87 is offline   Reply With Quote
Old June 26th, 2013, 05:43 PM   #3
joe_jeep
welfare wheeler
joe_jeep's Avatar
they make shock shifters that move them out a little to clear.
or many people just notch the back edge of the spring bucket.
easy cheap fix. totally common.
Old June 26th, 2013, 05:44 PM   #4
jimhri
jimhri's Avatar
sell it and let it become someone else's problem
jimhri is offline   Reply With Quote
Old June 26th, 2013, 05:47 PM   #5
jbsjunk
Little Member
jbsjunk's Avatar
Currie and BDS make a extension bracket that bolts on and moves the bottom of the shock away from the coil bucket.
http://www.4x4xplor.com/shock-extensions.html
Old June 26th, 2013, 06:40 PM   #6
I suck cocks. Lots of them.
locally famous
i like that answer,
Old June 26th, 2013, 07:27 PM   #7
Cummins-coal
Originally Posted by marshall View Post
i like that answer,
I'm starting to like that answer more and more also!
Page generated in 0.21767 seconds with 44 queries
