Engine swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 24th, 2013, 09:48 PM   #1
wordup
wordup's Avatar
Default Engine swap
Just need to know if a 1994 4.0 fuel injected out of a Cherokee , will that fit right in my 91 wrangler yj ?
wordup is offline   Reply With Quote
Old June 25th, 2013, 05:34 AM   #2
yyj87
yyj87's Avatar
The accesories may be different but you should be able to make it work.
1996 grand 4.0 into 1991 wrangler involved swapping intake manifolds.
yyj87 is offline   Reply With Quote
Old June 25th, 2013, 12:42 PM   #3
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
It depends on what you mean by "fit right in". Physically, yes, it is roughly the same size, so it will fit. Accessories, fuel, electrical, intake, exhaust, and probably a bunch of other things will be different.
Old June 25th, 2013, 05:13 PM   #4
yyj87
yyj87's Avatar
You will need to run all the accessories/intake from your original or the donor. Mixing may cause problems.
Page generated in 0.23348 seconds with 35 queries
