99 Jeep Grand Cherokee****sold****delete** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 22nd, 2013, 06:57 PM   #1
jfoster
jfoster's Avatar
Default 99 Jeep Grand Cherokee****sold****delete**
It was wrecked in the front. 4.0l,145k,Laredo.
both rh doors are gone.
Headlights $ 25 each,light haze.
Transfer case part time case $200
Rear driveshaft $25
Front manual seats,grey-a5az trim code $100 pair
Rr taillight $50
Lh mirror $30
Front drive shaft,cv slip- u joint style,$100
Alternator $30
Starter $30
4.0l Engine $750 145k
Rh axle shaft $30-recent replaced
engine computer,non-security,fitrs 99,4.0l only ---$85
The body went to scrap Monday July 8th#
Thanks for looking. Parts need to be picked up in Cadillac.
Jake
jfoster is offline
Old June 22nd, 2013, 09:37 PM   #2
revdog
How much for the front shaft, yoke off front axle, t- case and t case shifter bezel?
Sent from my DROID RAZR using Tapatalk 2
revdog is offline
Old June 23rd, 2013, 11:38 AM   #3
jfoster
jfoster's Avatar
By shifter bezel I assuming you mean shifter? . 400 for everything. If trying to make an awd a 2wd you will also need the two shifter bracket unless yours has hat already. I have that and will throw that in if you buy the rest.
Jake 231-920-5337, texts are ok until 9 pm
jfoster is offline
Old June 23rd, 2013, 12:13 PM   #4
revdog
Yup I'll need the brackets to. Good looking out. You have the plastic shroud for around the shifter , the part that says 2wd 4wd? Is this stuff out ready to go? I'll have Chad come over and pick it up.:-)
revdog is offline
Old June 24th, 2013, 11:25 AM   #5
Bruster
Windshield good?
Bruster is offline
Old June 24th, 2013, 12:32 PM   #6
tom tom
tom tom's Avatar
pics ??
tom tom is offline
Old June 24th, 2013, 07:59 PM   #7
jfoster
jfoster's Avatar
All parts are out and ready to go.
Jake
jfoster is offline
Old June 24th, 2013, 09:04 PM   #8
revdog
Cool. I'll get chad to get ahold of you and pick up the stuff I wanted.
revdog is offline
Old July 4th, 2013, 07:50 AM   #9
jfoster
jfoster's Avatar
sorry no windshield
jfoster is offline
Old July 7th, 2013, 11:33 PM   #10
topjimmyk
topjimmyk's Avatar
What are the lift details?
topjimmyk is offline
Old July 10th, 2013, 11:42 AM   #11
jfoster
jfoster's Avatar
Results for: 1999 Jeep WJ Grand Cherokee Suspension Lifts
Grand Cherokee WJ 4" Lift Kit System
J17
99-04 Jeep WJ Grand Cherokee 4WD
Price $699.95
jfoster is offline
Old July 13th, 2013, 02:11 PM   #12
joshua
i need the part for the driver's front door that keeps it propped open (it's an arm that bolts to the inside of the door, passes into the door jam, and then bolts to the body).
PM if you are willing to pull it out of the front door (don't need or want a whole door, sorry).
joshua is offline
Old July 14th, 2013, 07:13 AM   #13
jfoster
jfoster's Avatar
Sorry the body went to the scrapyard. I edited the post, and the parts and pieces listed are still available.
jfoster is offline
Old July 14th, 2013, 03:13 PM   #14
Paintballpsyco236
Paintballpsyco236's Avatar
Send a message via AIM to Paintballpsyco236 Send a message via MSN to Paintballpsyco236 Send a message via Yahoo to Paintballpsyco236
If you still have them, how much for the brake booster and master cylinder? Thanks,
Paint
Paintballpsyco236 is offline
Old July 18th, 2013, 02:49 PM   #15
jfoster
jfoster's Avatar
sorry do not have booster or master cylinder. went with the body to scrap.
jfoster is offline
Old July 19th, 2013, 01:59 PM   #16
Paintballpsyco236
No problem, thanks anyways. Did a bit more digging and it turns out the setup I already have is the exact same thing so swapping to the WJ parts would have only served to waste a lot of my time lol. Best of luck with everything!
Paint
Old August 21st, 2013, 11:51 PM   #17
vholdsworth23
vholdsworth23's Avatar
What shifter brackets do u need to put the 242 in ? I'm looking at doing the same thing.
vholdsworth23 is offline
Page generated in 0.33316 seconds with 75 queries
