Badmunkys 98 Lerado build. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 22nd, 2013, 04:56 PM   #1
Badmunky
Badmunky's Avatar
Default Badmunkys 98 Lerado build.
Ok so I have started to buy parts for the rig so I thought now would be a good time to post up my build thread.
First let me tell you my goal.
I'm looking for a reliable DD for the wife that can be taken on moderate trails and camping. More of an excursion/ expedition type vehicle then any thing.
The vehicle we chose to start with is a fairly clean 1998 Grande Cherokee Laredo 4.0.
So far I have installed new brakes all around.
New distributor cap. (Accel)
New rotor. (Accel)
New plug wires.
New plugs.
New wiper blades.
And new front sway bar bushings.
Fixed the parking brake.
Fixed a coolant leak. (Lose clamp)
Adjusted the tired steering box.
Removed the universal side steps that came with it.
And gave it a good cleaning.
Right now I have on order the following.
Flowmaster cat back.
OBX header.
A new flex section for the exhaust to take some of the stress of the header.
New front and rear O2 sensors.
Also ordered some 2.5" pipe and mandrel bends to make the front section of the exhaust out of.
Headlights. (Note: I did not want these. The wife over ruled me.)
2" budget lift. (Bout it used for $20. Just something to play with for now.)
I still need some more things for it and will be ordering more stuff today.
Right now its not running right. So I'm fixing every thing that's wrong with it first.
Then when its running right and has no problems I will start moding the crap out of it.
List of what it still needs.
99+ intake.
Steering box replaced. (Thinking I'm going to run the 99 Durango box.)
Fan clutch is locked up. Going to convert to electric.
Some the seals are leaking. Both motor and axles.
Needs a good service.
Going to have the small rust hole in the passengers rocker fixed.
Need a new right front fender. (Still looking for a black one.)
Need a new steering wheel. (96-98 leather.)
Need T-case shifter trim. (NP242.)
Looking for a drivers seat bottom. (Leather, black, no heat)
Need a new spare tire.
Need new speakers. (Has the infinity system but all door speakers are bad.)
Need new lift shocks for the hatch and hatch glass.
Need a new rear wiper arm.
Need new front door panels. (Leather is cracked really bad.)
Need new valve cover. (Rust.)
Need new CD player. (Stock wont play MP3s.)
Need to get an alignment. Drifts to the right a bit.
Then the moding starts.
I'm thinking it will end up on 33-35s with a 4.5 to 5.5" long arm kit.
Not sure what I'm going to do for axles just yet. But I'm not going to be beating the crap out of it, so I don't think I need any thing supper big. Just a good set that I can install lockers in that will do good with 33s-35s and not brake if I get a little to aggressive.
Then I will do bumpers, rock sliders, skid plates, and a roof rack.
Should be a real nice rig when I get it done.
This is about what I'm going for when I get it done.
Badmunky is offline   Reply With Quote
Old June 22nd, 2013, 05:02 PM   #2
Badmunky
Badmunky's Avatar
Also like this one.
Old June 22nd, 2013, 09:09 PM   #3
Badmunky
Badmunky's Avatar
Ordered set of remanufactured 703 fuel injectors.
And throttle body spacer.
Old June 22nd, 2013, 09:20 PM   #4
revdog
That silver on is nice. We have a trail only zj on 41s. Thinking about getting one as a dd. Seams your of to a good start with some nice parts.
Sent from my DROID RAZR using Tapatalk 2
revdog is offline   Reply With Quote
Old June 22nd, 2013, 09:26 PM   #5
Badmunky
Badmunky's Avatar
So far we like it.
Just need to get somethings fixed so it runs and drives right.
It wants to stall out about 100 feet after you take off with it when its been sitting for bit.
And its not idling as smooth as it should.
Also a little down on power.
Exhaust it cobbled together parts, and the converter has been cut open.
And the stock header is cracked bad.
But it has a lot of new parts and its kind of hard to find a solid 90s Jeep in Michigan these days.
But I got a good deal on it. $2,400 + tax, title, plate, and doc fee. $2,781 out the door form a dealer.
Right now I'm looking for a 63mm throttle body.
Old June 27th, 2013, 11:13 PM   #6
Badmunky
Badmunky's Avatar
More parts on the way.
DEI titanium heat wrap.
Magnaflow Converter 9410.
6 2.5" exhaust flanges.
3 45 degree 2.5" mandrel pipe bends.
3 90 degree mandrel pipe bends.
And some vent visors.
More to come as I get more cash and time.
Old June 28th, 2013, 04:08 PM   #7
montecarlo33
The Violator
montecarlo33's Avatar
any reason you want to wrap your header other than less under hood heat?
Old June 28th, 2013, 06:34 PM   #8
jbsjunk
Little Member
jbsjunk's Avatar
A lot of header companies won't warranty headers if they were wrapped. They hold heat in and make them more prone to cracking. Not that the mighty 4.0 needs any help there.
Old June 29th, 2013, 01:23 AM   #9
Badmunky
Badmunky's Avatar
No that's about it. Just want to lower under hood temps and stop some of the heat soak in to the intake manifold.
Yes I know. I have used OBX before and never had a problem with them.
If it cracks, Ill pull it and fix it, if they will not replace it. But I don't think it will crack.
I could not find any one running this header that had one crack. I'm sure some one did. But in my searching I found nothing.
And I'm adding a flex section to the exhaust just after the header to help with the cracking problems.
So I think I will be ok.
Page generated in 0.34181 seconds with 50 queries
