YJ: probably a stupid question. but none the less. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 21st, 2013, 03:02 PM   #1
mymizzery
mymizzery's Avatar
Default probably a stupid question. but none the less.
I am replacing one of the injector wiring harnesses, and I don't think there is any chasers on the wires. so I am assuming that it doesnt matter which wire I connect to positive, and negative. is this correct. I know its an easy fix, but I'd rather do it right the first time, and not have to take it apart again. it shouldnt matter, but I'll put it down anyways. 91 yj 4 banger.
mymizzery is offline   Reply With Quote
Old June 21st, 2013, 03:21 PM   #2
Lousypirate
Whoop Whoop
Lousypirate's Avatar
Not positive, but if you wired backwards the solenoid should push on the valve inside the injector instead of pull.
So yes it goes a certain way.
Unless there is something I don't know about gas injectors
Lousypirate is online now   Reply With Quote
Old June 21st, 2013, 03:24 PM   #3
buttercr125
I work out
buttercr125's Avatar
You are correct...there is something you don't know.
You are correct.
Old June 21st, 2013, 03:30 PM   #4
Klumpper
Fuck Cancer!
Take a pic of the connector on the injector, it will help in finding a spec for it, be it a bosch, marelli, delphi, or other injector.
Klumpper is offline   Reply With Quote
Old June 21st, 2013, 03:36 PM   #5
GREASYHANDS
GREASYHANDS's Avatar
Its just two wires how hard is it to put it back the way it came apart?
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old June 21st, 2013, 03:50 PM   #6
Klumpper
Fuck Cancer!
looks like a bosch injector with EV-1 connector.... with the harness connector and looking at the back side where wires come out with locking spring up, positive is on the right, negative on the left.
http://www.diyautotune.com/catalog/f...-ev1-p-48.html
how our test bikes are wired, can't find the spec sheet at the moment, must be friday afternoon!
hope it helps.
Old June 21st, 2013, 03:52 PM   #7
mymizzery
mymizzery's Avatar
well if I was reconnecting the same harness, it's not hard at all. but I am replacing the connector (with a new one) so I am just making sure there is no way of reversing the polarities on it. so instead of being a smart ass about it. a simple yes, you are correct, or no it does make a difference which wire is connected to positive and negative would have been a suitable answer. instead of making yourself look like a _______. I'll just leave that blank for other people to fill it in. but I have my opinoins.
Old June 21st, 2013, 04:52 PM   #8
kickstand
circling the drain
kickstand's Avatar
oh, lighten up francis
Page generated in 0.27762 seconds with 47 queries
