After market Cruise control - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 20th, 2013, 03:54 PM   #1
Default After market Cruise control
I got a 2007 E450 box truck with a V10. Its the older v10 not the style with the bad spark plugs. Trying to find a kit to put cruise on this thing. It has a/c but no cruise . Coming up short on finding anything with my limited research skills . Anybody know if any shops that do after market installs?
My understanding its the same platfrom as the motorhomes.
Things I find are like this, not a whole lot of info given.
http://www.thecruisecontrolstore.com...4/5C2Z9A818AAA
Old June 20th, 2013, 04:19 PM   #2
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Does it have a cable throttle or electronic?
Old June 20th, 2013, 04:22 PM   #3
I have to look, I thought about that after I posted. I should of looked before I posted.
Old June 20th, 2013, 04:23 PM   #4
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Pfffft. Yeah, no doubt. Geeeezzz.
Old June 20th, 2013, 04:27 PM   #5
I am pretty sure its cable. I'll verify tonight if I get it back (its loaned out at the moment). Get a box truck and everybody wants to borrow it
Old June 20th, 2013, 04:31 PM   #6
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
You could fill it with junk and park it at a friend's house.
Old June 20th, 2013, 04:34 PM   #7
frdboy
frdboy's Avatar
If it is elec. throttle you may be able to get a steering wheel with the buttons and then I can enable cruise in the PCM. I just did that on a 08 crown vic. The wiring was all there on that car but a big truck like that it probably will be not there...lol
Old June 20th, 2013, 04:56 PM   #8
Looking on Identifix it appears to be fly by wire. Which honestly would surprise me. I imagine the steering wheel on e250-450 would be the same.
Old June 20th, 2013, 06:59 PM   #9
It is fly by wire.
Old June 20th, 2013, 07:03 PM   #10
frdboy
frdboy's Avatar
Now you need to see of the clockspring and wiring is right.
Old June 20th, 2013, 07:04 PM   #11
I think its 03-07 only. Most searches show this as the interchange yrs.
Old June 21st, 2013, 09:21 AM   #12
So then it looks like this kit would work then? Looks I should start checking the local yards for the same parts but cheaper.
Old June 21st, 2013, 09:33 AM   #13
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Before you buy, you might want to chat with the ford dealer to see if they can enable it in their tool. It would suck to hook up everything and then find that the dealer programming tool is locked from adding the feature for some reason.
If they were to enable it before you install the switches, then I would guess the worst case would be that it would set codes for the buttons being missing.
Old June 21st, 2013, 09:36 AM   #14
I am gonna pull the wheel and check for the wiring before I spend anything. And if it does, I would go to a local pick and pull to find the parts. Worst case I install and doesn't work I have 30 days to return the parts.
Old June 21st, 2013, 09:43 AM   #15
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I missed frdboy's comment. Sweet. Carry on.
Page generated in 0.28554 seconds with 68 queries
